STM32CubeIDE (MCUs)
STM32CubeIDE 1.18.1 released
We are pleased to announce that the minor release 1.18.1 of STM32CubeIDE is available. What is new in 1.18.1: This minor release will not bring any major updates to the STM32CubeIDE 1.18.1. It will be aligned with the STM32CubeMX 6.14.1. Main fixed i...
STM32CubeIDE 1.18.0 released
We are pleased to announce that the release 1.18.0 of STM32CubeIDE is available. What is new in 1.18.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX 6.14.0: Added the support for STM32WBA6xxx microcontrollers in the STM...
STMCubeIDE does not create links to SPI HAL files
I am starting to use the H755Zi Nucleo board. I have been using the F767Zi and F746Zg prior to this and familiarity with STM32CubeIDE. I see that there are no examples for the H755Zi-Q, but there are for the H745Zi-Q and do seem to run on the 755 boa...
jdw by Associate II
  • 755 Views
Resolved! Rename the project does not rename the .ic file
I wanted to use the ioc and all the code from a project into another project. So, I copied the project and pasted in a workspace, then renamed the project, but ioc is not changed. So while opening, I get error messageInvalid Input: Must be project's ...
Techn by Senior III
  • 951 Views
  • 3 replies
STM32CubeIDE BUG with working CMake project
Hello,I have a working project based on CMake.I tried to build it under STM32CubeIDE with no success.Here is the output when trying to build the project:**** CMake Configure of configuration config_default for project CMakeProject **** C:\Work\Projet...
ANauz.1 by Senior II
  • 626 Views
  • 1 replies
STUSB1602 + STM32F446ZE
I am currently working on a project where USB-C PD stack implementation on STM32F446ZE board. I have downloaded the necessary files which I have shown in my attachment (zip folder downloaded from https://github.com/usb-c/STUSB1602). Kindly answer my ...
Disassembly view buggy?
This is using Stm32CubeIDE  Version: 1.14.0 Build: 19471_20231121_1200 (UTC)When I hit a breakpoint that says "view disassembly" that button often goes to a blank disassembly view. Same if you try and go to a particular address.  If you close the cur...
musmuris by Associate II
  • 1934 Views
  • 5 replies
  • 1 kudos
Unavailable FW package issue (fixed)
Dear STM32CubeMX/STM32CubeIDE users We detected an issue linked to unavailability of some Cube packages for multiple STM32 series. This misbehavior is caused by an issue in the published database used by our tools. The issue is currently under invest...
