STM32CubeIDE (MCUs)
STM32CubeIDE 1.17.0 released
We are pleased to announce to you that the release 1.17.0 of STM32CubeIDE is available. What is new in 1.17.0: Microcontrollers, microprocessors, and board lists aligned with STM32CubeMX: Added the support for the STM32N6 seriesAdded the support for ...
Resolved! linker file
The wizard procedure put in my project this file <STM32U575ZITXQ_FLASH.ld> and this file <STM32U575ZITXQ_RAM.ld>.When is used the first and when the second and where is written in the project which one to use?Because in the linker section, as for Deb...
IVent.1 by Senior
  • 1481 Views
  • 1 replies
  • 1 kudos
STM32F4 libusb-win32 with FREERTOS problem
Hello, I'm using STM32F407VGT board to send and receive data to/from a Nodejs application via libusb. This works correctly when not using freeRTOS, but as soon as i create a freeRTOS task or use any CMSIS function such as  osDelay() the board's usb d...
stm32f407 ftp client
helloim using stm32f407vgt6 and cubeide without os.i configured ethernet using cubemx perfectly.now i need ftp client, i cant find proper resources for do this.thanks for your helps.
Resolved! Code generation - ADC3 prescaler
In the IDE GUI, when selecting asynchronous clock division for ADC3 on STM32H747XIH, the value generated in the code seems to be taken from ADC1, e.g.:ADC1 (divided by 4):ADC3 (divided by 6):generated code (shortened):/* ADC1 init function */ void MX...
heveskar_0-1713024808318.png heveskar_1-1713024842396.png heveskar_2-1713025453593.png heveskar_3-1713025453592.png
STM32CubeIDE hangs on close
STM32CubeIDE hangs on close, on macbook air mac os Big Sur CPU: Intel core i3. After forced closing, the next time you start STM32CubeIDE, it opens some strange interface that is different from the usual interface (I attach the screen), this problem ...
IAKHM.1 by Associate II
  • 997 Views
  • 4 replies
Resolved! Use SD Card/ FATFS
Good morning, I am looking to write data in csv format to my SD card with an SD shield. So I activate the SDMMC1 port and the FATFS driver for my SDMMC1 port, when I generate I then have 300 errors on my HAL header. Do you have any idea what the prob...
MickaelRacloz_1-1713253202127.png MickaelRacloz_2-1713253226959.png MickaelRacloz_3-1713253309413.png
Resolved! C++ compile multiple definition
Hi,I have a C project, it compiles perfectly.I changed the extension of main from main.c to main.cpp.I use the function "Convert to C++", I did "Clean project"but when I compile the project, I have a bulk of compiling error of this type:C:/myproject/...
IVent.1 by Senior
  • 1921 Views
  • 6 replies
  • 3 kudos
Resolved! Optionally adjust the clock of the ADC
Hi I'm KIM from south Korea. My MCU is "STM32H735ZGT6". I want to change the clock of ADC1 within the code.I set up the clock of ADC1 in CUBEMX Clock Configuration about 80Mhz, but I want the clock of ADC1 about 75Mhz. How can I change the clock? Tha...
giwonKIM by Associate III
  • 655 Views
  • 4 replies
  • 1 kudos
STM32CubeIDE CMake with Ninja???
Does anyone know how to coax cube IDE into wanting to use ninja as the build tool with a CMake project?  I’ve been away from cube IDE for a while but the allure of CMake and advanced debugging has sucked me back in again. I’m on MacOS and ninja is av...
svcguy by Associate III
  • 507 Views
  • 0 replies
  • 1 kudos
