STM32CubeIDE (MCUs)
STM32CubeIDE 2.1.1 released
We are pleased to announce that the minor version 2.1.1 of STM32CubeIDE is available. What is new in 2.1.1: This release covers the topics listed below: SEGGER J-Link GDB server updated to 9.24 to fix an issue with the Live Expression view during the...
Aimen1 by ST Employee
  • 1632 Views
  • 0 replies
  • 1 kudos
STM32CubeCLT 1.21.0 released
We are pleased to announce that STM32CubeCLT 1.21.0 release is available. What is new in 1.21.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.1.0Update of Clang/LLVM toolchainUpdate of GCC to GCC 14Update of STM32Cu...
  • 613 Views
  • 0 replies
Resolved! How to generate a *.bin file instead of a *.elf file
hello ST Community,Is it possible to generate a binary file that is a *.elf file from a project developed by STM32CubeIDE?Using the correct settings for generating *.bin files.The *.bin file would be used to create a bootloader via UART for one of th...
Domy_ST by Senior
  • 585 Views
  • 4 replies
  • 3 kudos
stm32cubeide compilation speed issue
Hi, I'm using stm32cubeide version 2.1.1 and version 1.15.1/windows11, both are compiling the same project on my PC at slower speed compared to a lab computer.(3min vs 20seconds) Any idea what could be causing the issue? Thanks!
Resolved! NUCLEO-L452 STLink debugging external MCU using SWO
What could be the reason that configuring in CubeIDE SWV as enabled the MCU on debug flashes and stops responding? Flashing works fine both ways, SWO is connected. Time elapsed during verifying operation: 00:00:00.082Download verified successfullyTar...
KaLiO by Associate II
  • 469 Views
Resolved! NUCLEO-U3C5ZI-Q project has no .ioc file
I'm trying to create an empty project for the NUCLEO-U3C5ZI-Q using STM32CubeIDE v2.1.1 under MacOS. All available updates have been applied.I've used File/STM32 Project Create to create an STM32CubeIDE Empty Project for the NUCLEO-U3C5ZI-Q board (al...
CTapp.1 by Senior III
  • 422 Views
  • 3 replies
  • 2 kudos
Include path in c++ Cube IDE
Hello,I am converting from Arduino to STM 32 Cube IDE. Here I have a Problem with include paths:What I want:- Develop Libraries in a special folder- Add the libraries as a LINK to the Cube IDE- use #include command to include the library into the pro...
DocAlex by Associate III
  • 2751 Views
  • 3 replies
  • 2 kudos
Resolved! st link debugging issue
hello team, I am facing a debug connection issue with STM32H723VGTx using STM32CubeIDE and ST-LINK.Issue details:MCU: STM32H723VGTxDebug tool: ST-LINK (OpenOCD via STM32CubeIDE)Interface: SWDReset mode: Software resetSWD frequency: 50 kHzObserved beh...
manoj3 by Associate II
  • 904 Views
  • 11 replies
  • 3 kudos
setting during Build & Debug
hello ST Community,where can I set it to avoid generating the file "startup_stm32l5...zetxq.s" during compilation and debugging in the stm32CubeIDE environment and also how to avoid that the space bar "|" when editing the line of code of 'main.c' is ...
Domy_ST by Senior
  • 328 Views
  • 5 replies
Announcement
We’re moving the ST Community to a new platform to give you a better and more reliable community experience.
