STM32CubeIDE (MCUs)
STM32CubeCLT 1.20.0 released
We are pleased to announce that STM32CubeCLT 1.20.0 release is available. What is new in 1.20.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.0.0Update of Clang toolchain version 19.1.6Update of GCC 13.3.rel1Update ...
Aimen1 by ST Employee
  • 700 Views
  • 0 replies
STM32CubeIDE 2.0.0 released
We are pleased to announce that STM32CubeIDE 2.0.0 release is available. STM32CubeIDE is now independent from STM32CubeMX. With this release, device configuration, previously handled within STM32CubeIDE via STM32CubeMX, is now exclusively available t...
  • 9738 Views
  • 0 replies
  • 5 kudos
Resolved! Warning when generate project with LPBAM - Stm32u575
Hi, I am creating application using LPBAM configuration. The application simply is:Enter stop mode 2- Use ADC4-12bit channel 22 (PC4) to measure voltage using clock HSI or MISK- ADC wdog to generate interupt when the value reach threshold to exit sto...
BLS_Karo_0-1766680772291.png BLS_Karo_1-1766680910394.png BLS_Karo_2-1766680952577.png BLS_Karo_3-1766681008354.png
BLS_Karo by Associate II
  • 202 Views
  • 1 replies
Resolved! [Resolved] STM32CubeIDE project creation issue
Updated post to reflect permanent fix Dear STM32CubeIDE user, Further to the recent STM32CubeIDE project creation issue, we would like to inform you that a solution is now available for you. This permanent fix applies to all STM32CubeIDE versions. I...
Resolved! Problems with GDB Server
I am using STM32CubeIDE V1.11.0I have exactly the same issue which was described in this post:https://community.st.com/t5/stm32-mcus-boards-and-hardware/st-link-gdb-server-issues/m-p/64010#M623Multiple weeks everything works fine. But suddenly it sto...
Moritz1 by Associate III
  • 12873 Views
  • 13 replies
ThreadX or FreeRTOS with FileX?
Hi,This is for STM32U5 and STM32H7 series MCUs.I was starting to use ThreadX because it looked like it was preferred over FreeRTOS. Now it looks like it is going the other way FreeRTOS is preferred over ThreadX ... or so I read/watched.I liked Thread...
Rodo by Senior
  • 330 Views
  • 1 kudos
Resolved! AES in CTR Mode: IV not saved to IOC file
Hello,I'm facing an issue in CubeMX with the AES IV in CTR ModeThe IV is not saved in the IOC file and is discarded from the generated code, replaced with a full 0 value.The AES content inside the IOC file:AES.Algorithm=CRYP_AES_CTRAES.DataType=CRYP_...
zeboss49 by Associate III
  • 275 Views
  • 4 replies
  • 1 kudos
Recognizing a project by reading the flash
 It happens to from time to time that I have a flashed project in a hardware, e.g. a bluepill, but I forgot which source project was belonging to it in the STM32CubeIDE's project treeview.Is there a way to write the name of the project by means of so...
