STM32CubeIDE (MCUs)
STM32CubeCLT 1.20.0 released
We are pleased to announce that STM32CubeCLT 1.20.0 release is available. What is new in 1.20.0: Maintenance of the previous version: Updated in accordance with STM32CubeIDE v2.0.0Update of Clang toolchain version 19.1.6Update of GCC 13.3.rel1Update ...
Aimen1 by ST Employee
  • 700 Views
  • 0 replies
STM32CubeIDE 2.0.0 released
We are pleased to announce that STM32CubeIDE 2.0.0 release is available. STM32CubeIDE is now independent from STM32CubeMX. With this release, device configuration, previously handled within STM32CubeIDE via STM32CubeMX, is now exclusively available t...
  • 9654 Views
  • 0 replies
  • 5 kudos
Resolved! Signal Pass through using ADC and DAC
The equipment I am using is the following: Nucleo-Board L476RG, STM32CubeIde 1.10.1. I am attempting to design a simple dsp system that uses an ADC to send the data it receives from a function waveform generator to a DAC, and the DAC output will then...
JEscu.2 by Associate II
  • 4465 Views
  • 7 replies
Refresh files to compile after prebuild steps
I run my python script in C/C++ Build --> Settings --> Build Steps --> Pre-build steps by running command:cd ${ProjDirPath}/menu_language_generator && python generate.pyThis script generates header files to my project with langauge translations. Scri...
DBrau.2 by Associate III
  • 768 Views
"Dwarf Error" error after new installation
 Hello friends, thank you for your help.My main problem is that none of the new projects I open on my newly installed STM32Cube on my computer work, but when I import my old projects, they work.part number: stm32f103c8 Environment: STM32CubeIDE / Ver...
Unable to Download STM32CubeIDE
Hi everyone,I'm having trouble downloading STM32CubeIDE. Even though I'm registered, There seems to be somthing broken with the Web page.I’ve tried multiple browsers, but still no luck. I also haven’t received any email with a download link.I’ve been...
cerine by Associate II
  • 1912 Views
  • 6 replies
  • 1 kudos
Stm32H747I-DISCO Share Peripherals
Hi Is it possible to share some peripherals between cores?My goals is to share the SD card  trought CM7  and CM4 using hardware semaphore for the access(one SD hardware but both cores can write and read on it sharing the SD pins).Using Stm32CubeIDE i...
DMazz.1 by Associate II
  • 552 Views
  • 1 kudos
Resolved! SDRAM and a global struct.
Hi.I am using TouchGFX and it works fine,My MCU is STM32H743 But when I use the SDRAM for other things the code does not work.My question is:Can I use struct in the  SDRAM.? I have this one in my c file.  SD_CARD SdCard __attribute__((section("\"SDCa...
Hector_R by Associate II
  • 1508 Views
  • 10 replies
Resolved! CubeIDE issue with timers
Hello,I'm facing a very annoying issue in CubeIDE.Board: Nucleo-F412ZH.The project uses TIM1 Channel4 to genrate a Stream of PWM pulses to drive a WS2812B LED strip using DMA.It also uses TIM9 to generate the systick.With this configuration, the MCU ...
zeboss49 by Associate III
  • 1090 Views
  • 3 replies
  • 3 kudos
