STM32 MPUs Products
How to remove "sound" from DTS?
I am trying to use the 40 pin GPIO, namely pin 48 and pin 40 which are PF11 and PI6. PI6 is assigned to sai2. I've disabled sai2. However, the DTB will not compile because there is still a reference to the sai2 pins here:sound:sound{ compatible = ...
DDR addr bus test Error in STM32MP153A
We modified the device tree file corresponding to our development board based on stm32mp157d-ev1.dts.We did not use a PMIC chip, so we added our own power node and modified the default serial port output.This is my device tree file:The following erro...
DG by Associate II
  • 827 Views
  • 3 replies
STM32MP151 change default UART
We want to change default uart from UART4 to UART8,from:aliases { ethernet0 = &ethernet0; serial0 = &uart4; .... };we changedserial0 = &uart8;and implement uart8 as below:&uart8 { pinctrl-names = "default", "sleep", "idle"; pinctrl-...
Dat Tran by Senior II
  • 369 Views
  • 1 replies
IWDG not able to trigger reset in U-Boot/Kernel
On an STM32MP157C the IWDG is setup correctly, but when I trigger an endless loop in U-Boot or a panic in the Kernel, after the timeout the reset does not work. All I know is that the debugger shows a Vector catch. In OPTEE OS the reset works. Is thi...
johnnyc by Associate III
  • 430 Views
  • 1 replies
Resolved! extlinux.conf can't chose uInitrd boot
hi st expert​I am porting openstlinux for my robot board, I found that the system froze after uboot selected the extlinux file, and then rebooted after a while,the uart log :Do I have any debugging means to analyze where the current problem is? than...
ttao.1 by Associate II
  • 778 Views
Watchdog restarting issue in STM32MP157.
Hello We are implementing WWDG watchdog in our custom board to cortex-M4 core in cubeIDE tool. We initialise the following registers -> enable the clock to WWDG -> In control register enable the Watchdog enable bit and watchdog counter. -...
