STM32 MPUs Products
STM32MP135F Clock Config
I'm unable to set the clock frequency above 650Mhz, but according to the datasheet, the mpu i selected should be able to reach 1000mhz. What am I doing wrong?
openamp: OpenAMP_TTY_echo
Hello!If I run the openAMP example I can see the two new devices appear in the linux /dev folder: ttyRPMSG0 and ttyRPMSG1, so that's fine!I would like to give these entries another name, like instead ofttyRPMSG0 --> KEYSttyRPMSG1 --> FRAMQuestion 1: ...
EOF by Associate II
  • 231 Views
  • 0 replies
Resolved! STM32MP135 TZC Errors At Linux Kernel Load (256MB RAM)
EDIT: Sorry I accidentally put this in the wrong topic.Hi,I am trying to bring up a board using a STM32MP135 and 256MB RAM (using one of these). I have followed the Wiki instructions to modify for 256MB RAM, and the project previously worked fine. Th...
TommyTom by Associate II
  • 526 Views
  • 1 replies
Quad SPI Transmit issue
 I'm working with the STM32MP131FAE in a bare-metal environment, and I'm experiencing issues with QuadSPI.I want to use Quad SPI to send 96 bytes of data continuously without any clock interruptions.However, currently, the data is being sent in chunk...
Stnoobs by Associate II
  • 206 Views
  • 0 replies
Resolved! Linux image for a qt based app
Hi there STM team!I need to build a embedded Linux image for a STM32MP15 target. My application has a QT GUI already implemented. What is the best approach to create this image? I know OpenSTLinux exist but I don't fully understand what's the advanta...
JPabl.1 by Senior
  • 390 Views
  • 1 replies
  • 1 kudos
No interrupt generated on USB Host for STM32MP135F-DK
Hi all,I'm trying to enable the host functionalities for USB Port1 for MP135: I imported the Host Library and implemented some functions on usbh_conf.c file. Attached to the DK board I have a optic mouse.After some basic initialization I'm in the USB...
SteMMo by Associate III
  • 385 Views
  • 3 replies
build image
after following the bellow steps and in build-<distro>-<machine>/tmp-glibc/deploy/images/<machine> directoryi cant find the file system image(FlashLayout_sdcard_stm32mp157d-dk1-optee.tsv) in this directory as i am using stm32mp157d-dk1 and it contain...
Charan28 by Associate
  • 275 Views
  • 1 replies
