STM32 MCUs Wireless
Matter software expansion for STM32Cube
Dear all, The X-CUBE-MATTER Expansion Package is now available on our official website following this link  MATTER - Matter software expansion for STM32Cube - STMicroelectronics  It is a reference implementation for the demonstration of Matter on ST...
Ouadi by ST Employee
  • 741 Views
  • 0 replies
  • 2 kudos
Which EVK should be used for STM32WB55CG.
I am working on a lorawan project targeted at STM32WB55CGT6. It is QFN48 and I tried running the successful project on NUCLEO-WB55CG. The development board is QFN64. Would I be able to use the same Nucleo board for further development for STM32WB55CG...
PMana.1 by Associate II
  • 505 Views
STM32WB Switch mode ( BLE ) / (No BLE standby) + RTC calender + SRAM2A retention. working Example Included. Question.. Is this the best way???
working example Included/provided..So I have been working to get to the point where I can switch between between two modes.Mode 1 = BLE working with RTC calender and Low Power + my application, with <= 50uA current consumption.And Mode 2 = MCU is in ...
lizerd by Associate III
  • 444 Views
  • 0 replies
STM32WB_Getting Started PPT
Hello,I am following the STM32WB+Getting_Started_with_CubeMX_for_BLE_V07 ppt and was having an issue seeing "MyCST" on the ST BLE Sensor App.I am able to see MY_CUSTOM on the Light Blue App and seems to be able to connect and has my two characteristi...
kcire L. by Associate III
  • 346 Views
  • 1 replies
  • 1 kudos
Basic information question
I have a GPIO callback (using HAL) and would like to identify which GPIO brought me into the callback and then clear that interrupt flag (the appropriate bit in the PR register), however after looking at the UG in EXTI PR1 I see no definitions of the...
SWenn.1 by Senior III
  • 336 Views
  • 3 replies
Target not connected: NUCLEO-WB55RG
I am using  NUCLEO-WB55RG for developing a lorawan project targeted to  STM32WB55CG chip. I successfully downloaded the code using Keil IDE. When I was loading the code the windows machine was showing there is 3MB of space. I could run the code and d...
0693W00000GWaTHQA1.png 0693W00000GWaTCQA1.png 0693W00000GWaSsQAL.png 0693W00000GWaSdQAL.png
  • 655 Views
  • 4 replies
  • 1 kudos
STM32WB SRAM2
So once again I have a problem with the STM32WB , I have spent alot of time with the L4 series, and always used the SRAM2 retention in standby function without any problem. And the WB series should be based on the L4, so I had hope for an easy migrat...
  • 1390 Views
  • 3 replies
  • 1 kudos
