STM32 MCUs TouchGFX and GUI
X-CUBE-TOUCHGFX 4.24.2 is out!
TouchGFX 4.24.2 is now out. Please follow this link to download it.Release details: Release date: December 18th, 2023 New TouchGFX Core Features: Added libraries for cortex M55.We're happy to share a new TBS in the TouchGFX Designer based on this co...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
FONT, TEXT EXTERNAL, INTERNAL FLASH MEMORY
TouchGFX+LCD controlExternal flash memory is being used.However, when TextArea is used, TEXT is not displayed properly.So, I used INTERNAL FLASH MEMORY only for TEXT and FONT and it worked normally.What am I missing??The memory settings are as follow...
jschoi by Associate II
  • 403 Views
  • 1 replies
Resolved! ST7789V issue with DMA
Hello!I'm using a 320x240 TFT display with ST7789V driver and SPI interface by X-CUBE-DISPLAY. Pixel transfer works correctly when I use the BSP_LCD_WriteData function. I can also display images and animation using the TouchGFX framework.However, whe...
Dadigno by Associate III
  • 1158 Views
  • 4 replies
  • 1 kudos
Touch GFX example does not generate IDE project
I have made many tutorial examples of touch GFX projects but I have never tried seeing the code from one of the given examples. When I picked the Flex button example and generated the code I noticed I could not only not open a STM32 project to see th...
tmehok by Associate III
  • 342 Views
  • 1 replies
touchgfx textarea is wrong
디스플레이를 터치하면 글자가 깨지거나 이상한 글자가 표시됩니다. 그리고 screen1에 여러 글자를 입력했는데 놔다 켜면 글자가 이상하게 나옵니다. 도움을 주세요.  이 사진은 touchgfx로 디자인된 오리지널 사진입니다.보드에 이것을 업로드하면 위에처럼 이미지가 사라지거나 이상한 텍스트가 포함되는 경우가 있습니다.
화면 캡처 2024-07-05 145554.png KakaoTalk_20240705_145528083_01.jpg KakaoTalk_20240705_150236158.jpg
  • 1694 Views
  • 11 replies
  • 2 kudos
