STM32 MCUs TouchGFX and GUI
X-CUBE-TOUCHGFX 4.24.2 is out!
TouchGFX 4.24.2 is now out. Please follow this link to download it.Release details: Release date: December 18th, 2023 New TouchGFX Core Features: Added libraries for cortex M55.We're happy to share a new TBS in the TouchGFX Designer based on this co...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
STM32L476 + RGB interface
Hello, everyone!I'm developing smartwatch as a project and I'm planning to use a TFT display which has 18RGB interface. I have STM32L476 at my disposal that doesn't have any embedded LTDC module. Should I change MCU to one that does have LTDC in orde...
Error in code generation for TouchGFX
Hi,When I generate the code with STM32CubeMX version 6.3 for STM32H747XIHx something like this happens: I have also noticed that when I chose TouchGFX component I am able to use it only with M4 core (this configuration was forced by CubeMX) what is a...
aroni525 by Associate II
  • 2968 Views
  • 14 replies
TouchGFX 8bpp color format
Hey!I'm having wrong colors issue when drawing shapes with 8 bpp color format. It's clean simulator project with only color format settings changed. How to fix that?Images attached.Thanks
VLau by Associate III
  • 869 Views
  • 3 replies
scroll list add and remove elements
Hi,I want to create a scroll List where the elements have to be added or removed. I tried using remove but not able to remove elements even through call back like scroll list.is there solution?or how can I use remove ?Thankyou,
Revanth by Associate III
  • 736 Views
