STM32 MCUs TouchGFX and GUI
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
snprintf on wildcard only once
Hi friends, I have this problem:static uint16_t txt[10];Unicode::snprintfFloat(txt,6U,"%0.2f",functionGetFloat());Unicode::snprintf( TextIndicatorBuffer,TEXTINDICATOR_SIZE,"%s %s",TypedText(T_STATEPRODUCTMANAGERWC5).getText(),txt);TextIndicator.setWi...
Resolved! HAL_DSI_Read() - how to use it??
For a test I try to read current LCD brightness - 0x5E register using STM32F769-DISCO board with MB1166 OTM8009A LCD.DSI has been properly configured for the command mode - writing works OK. I know because display gets properly initialized.I looked e...
TDJ by Lead
  • 1698 Views
  • 4 replies
  • 1 kudos
Error Touchgfx by stm32h723
Hello, I have created a project to launch Touch GFX by stm32h723 , which I have put the download link below. Unfortunately, according to the photo I posted, it is displayed incorrectly on the LCD when it is launched, while I have separately tested th...
mbagh.1 by Senior
  • 1939 Views
  • 3 replies
  • 1 kudos
Resolved! Result with unit display
Hi,I'm in the process of implementing a result screen which displays the result along with unit.Since the digits are not the same I see a spacing issue between result and result unit.Example : 11 cm , 22cmand 99 cmI cannot have a fixed x and y co ord...
KNara.2 by Associate III
  • 737 Views
  • 1 replies
  • 1 kudos
Resolved! Unicode::UnicodeChar strncpy
Hello. I'm trying to pass wildcard buffer to model.hpp and convert Unicode::UnicodeChar to char and I'm using strncpy.  But it copies only one character.. Where is problem here? Also if I copy Unicode::UnicodeChar to Unicode::UnicodeChar buffer it wo...
heyo by Senior
  • 1052 Views
  • 1 replies
  • 1 kudos
STM32F769 jpeg header decoder Problem
hiI am practicing jpeg hardware decoding with stm32f769 disco board. During practice, some images were displayed normally, but some images could not be displayed at all.  I tested with this :STM32Cube_FW_F7_V1.17.0\Projects\STM32F769I-Discovery\Examp...
