STM32 MCUs TouchGFX and GUI
X-CUBE-TOUCHGFX 4.24.2 is out!
TouchGFX 4.24.2 is now out. Please follow this link to download it.Release details: Release date: December 18th, 2023 New TouchGFX Core Features: Added libraries for cortex M55.We're happy to share a new TBS in the TouchGFX Designer based on this co...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
How to do a page down/up with a list
I have this ui requirement  The idea is that when the user presses the "down" button, the effect will be to go all the way down, or all the way up.  I'm using a scrollable container with a list layout to create the view, how can I do it?
JPabl.1 by Senior
  • 262 Views
  • 2 kudos
Resolved! TOUCHGFX: is multi display possible ?
Hi,For a project I am currently working on, we have a unique custom board model on which we can flash different targets of a a same program.Depending on the target, we can work with one of two different displays, a 240x320 and a 160x80.For now, we tw...
SMarie by Senior
  • 416 Views
  • 2 kudos
User uploading file
Hello, is it possible to allow a user to upload a file to the display? For example, if there was a usb input, the display, can read the contents or write to the usb?
Priyank by Associate III
  • 134 Views
  • 1 replies
  • 1 kudos
Resolved! touchgfx simulator screen size scaling factor
hi,    Recently I notice that toucgfx simulator screen size is twice the value set in toucgfx designer, if I want the exact pixel size set in touchgfx designer while simulating, is there a scaling factor or some function to call? thanks for your time...
Resolved! TouchGFX gauge glitch
Hi,I'm using a custom H7 board, with QSPI + 16-bit SDRAM, and using RTOS.However I run into an issue where there's glitching in my gauge in TouchGFX (see attached video...)TouchGFX is using double buffer, also animationStorage: setFrameBufferStartAdd...
wlynn777 by Associate III
  • 7502 Views
  • 25 replies
  • 2 kudos
Resolved! CubeIDE don't generate C Files at all
Hello, at first im new in the STM32 world. Yesterday I set up the Touch GFX as "How to TouchGFX: Installing TouchGFX Designer for STM32 GUI applications" tells me. For that i delete all STM Programm tha i install pervius. Download lates Version and s...
Peter57 by Associate II
  • 1176 Views
  • 10 replies
  • 2 kudos
