STM32 MCUs TouchGFX and GUI
X-CUBE-TOUCHGFX 4.24.2 is out!
TouchGFX 4.24.2 is now out. Please follow this link to download it.Release details: Release date: December 18th, 2023 New TouchGFX Core Features: Added libraries for cortex M55.We're happy to share a new TBS in the TouchGFX Designer based on this co...
TouchGFX documentation feedback
We wish to always improve our documentation. The best reviews and critics always come from the people that read it, so we would like to use this post to collect your thoughts and feedbacks. Please share what you like, dislike, what you think is missi...
Share your Custom Widgets!
When creating a UI project, you may need widgets that are not part of the TouchGFX library. To create your own graphical element, the TouchGFX team suggests using the Custom Container approach. Since TouchGFX 4.20 it is possible to export and import ...
Resolved! Changing from LCD16bpp to LCD8bpp
Hello, I am facing an issue where the rendered frame buffer is printed on the display as gibberish pixels.I'm using the Nucleo F746ZG and interfacing it (over SPI) with an external display controller that writes to a 240*320 display. I was not able t...
bornamm by Associate II
  • 1426 Views
  • 9 replies
  • 1 kudos
Bug report: Wildcard use and swapping text.
Hello,I found an "edge" case with TouchGFX Designer.I have a message box that can swap syntax between language and wildcard count.think of:-ID1: "Clock stop"-ID2: "Clock <min>"-ID3: "Clock <sec>.<usec>"I was able to set a base class with id3 and both...
Marc_LM by Associate III
  • 132 Views
  • 1 replies
  • 1 kudos
How to know the active screen from model.cpp
I would like to check which screen is activated from model.cppI tried to use getCurrentScreen() in touchgfx::Applicationhttps://www.touchgfx.com/documentation/html/classtouchgfx_1_1_application_af560e49a149b6d2d0ccffd4ca42e5991.html#af560e49a149b6d2d...
COSEBE by Senior
  • 1796 Views
  • 6 replies
  • 7 kudos
Resolved! Callbacks between container and view
Hi, I went through some other discussions discussing a similar problem, but they did not seem to help. I have screen one which displays (dynamically) a container. The container has a button on it, which when clicked, changes screens to screen 2. At t...
Priyank by Associate III
  • 1022 Views
  • 13 replies
  • 1 kudos
Whether Video is support in STM32U5 controller?
Hi,I am having STM32U575 boards with me and I am able to use a simple TouchGFX project with U575ZI_GFX02Z1 example from TouchGFX.I tried embedding example Video from TouchGFX and my compilation fails for the below error:(.text._ZN8touchgfx11VideoWidg...
mdalal by Associate III
  • 194 Views
  • 1 replies
Add numeric keypad display
I'm just starting to use touchGFX and am trying to figure out the best way to design the functionality I need. I need a numeric input panel along with a display of the number that was entered. I need 10 digits (0-9), decimal point, a backspace, and a...
