X-CUBE-SBSFU CAN bus support
Vadym
Hi everybody!
We have to implement firmware update feature via CAN interface. Our challenge involves implementing a secure and safe firmware update feature via the CAN bus, driven by regulatory requirements in the medical field. Unfortunately, the exact specifications are currently unknown.
I found X-CUBE-SBSFU and it seems like a great solution. However, I can't find any reference or example where X-CUBE-SBSFU is can be or used with CAN interface.
Is it possible to use the X-CUBE-SBSFU solution with CAN interface (by implementing "CAN loader" for example)?
Thank you in advance!
7 REPLIES 7
Vadym
Did anybody have experience using X-CUBE-SBSFU with CAN bus?
CMYL
Hi @Vadym,
I' m checking internally if some demo is available with CAN !
Best regards
SofLit
Same question here.
PS:
Hi @CMYL ,
CAN Based Demo available? for SBSFU
Best regards
Still there No Update for SBSFU CAN Based Example
Best regards
Hello, any update regarding this topic ?
@SofLit the same question was asked yes, but both are unanswered...
Hello @hpons
Sorry for the delay.
A ticket is submitted internally to provide either example of guidelines how to support CAN.
Ticket number (Ticket 202646: stm32H743 SBSFU through CAN Protocol guidelines ?) (This is an internal support Ticket for Tracking not usefull for you)
Best Regards,
Younes
