X-CUBE-SBSFU CAN bus support
Vadym
Hi everybody!
We have to implement firmware update feature via CAN interface. Our challenge involves implementing a secure and safe firmware update feature via the CAN bus, driven by regulatory requirements in the medical field. Unfortunately, the exact specifications are currently unknown.
I found X-CUBE-SBSFU and it seems like a great solution. However, I can't find any reference or example where X-CUBE-SBSFU is can be or used with CAN interface.
Is it possible to use the X-CUBE-SBSFU solution with CAN interface (by implementing "CAN loader" for example)?
Thank you in advance!
5 REPLIES 5
Vadym
Did anybody have experience using X-CUBE-SBSFU with CAN bus?
CMYL
Hi @Vadym,
I' m checking internally if some demo is available with CAN !
Best regards
SofLit
Same question here.
PS:
1 - This is NOT an online support (https://ols.st.com) but a collaborative space.
2 - Please be polite in your reply. Otherwise, it will be reported as inappropriate and you will be permanently blacklisted from my help.
Hi @CMYL ,
CAN Based Demo available? for SBSFU
Best regards
Still there No Update for SBSFU CAN Based Example
Best regards
