STM32 MCUs Security
STM32H563 Warning: The Core is locked up
Hi,I'm currently developing a custom application which provisions and regresses an STM32H563, using the NUCLEO-H563ZI board for development.The CubeProgrammer CLI commands I'm executing are based on the bash scripts generated by CubeMX. Since I start...
Resolved! SBSFU STM32H7 script
Hello,   These are the scripts available for the L4 series, Can the same scripts be used for H7 series MCUs. If not, are there any specific scripts/commands needs to be followed.     Regards,Devank J
Devank_J by Associate II
  • 222 Views
  • 3 replies
  • 1 kudos
STM32H573xx: update with ST-JLINK
In the case of a root of trust with two boot stages (STiRoT + OEMuRoT), I'm looking to update the OEMuRoT or the firmware. From STM32CubeProgrammer I can do this via the bootloader. However, when I use the ST-LINK probe and try to program the new fir...
Secure H743 firnware programming GUI tools
I've read the X-CUBE-SBSFU Secure Boot and Secure Firmware documents and it doesn't explain if these are tools, with GUI, or just an API, which should really be explained at the start.If you know all about it I am sure these documents are just great,...
Robmar by Senior III
  • 213 Views
  • 4 replies
  • 2 kudos
Resolved! SBSFU Rollback with stm32L476RG
Hi All,I am following the UM2262 document. I will add a screenshot. I enabled the ENABLE_IMAGE_STATE_HANDLING flag to enable rollback, but after updating UserApp.bin, the device continues to reset. I will add a debug log screenshot (it’s not jumping ...
