STM32 MCUs Security
Resolved! "Download without debug" doesn't use jtag ?
Hello,In secured boot getting started it is said:"Download the SB SFU project software to the target without starting a debug session(Security protections managed by SBSFU forbid JTAG connection as it is interpreted as anexternal attack)"Does it mean...
ranran by Senior II
  • 684 Views
  • 3 replies
Resolved! End of program code address
Hello everyone,I'm tring to implement a calculation of firmware CRC in run time mode.Is there inker command method to acquire last address where code is written?I'm quite confident there is a specific command like __text_end__, for example.Best reg...
Resolved! X-CUBE-SBSFU for STM32H7 ?
Hello,Can X-CUBE-SBSFU source code work with STM32H7 (STM32H743) too ?In the getting started it is said:"It comes with an example implementation running on the NUCLEO-L476RG, NUCLEO-L432KC, B-L475E-IOT01A, 32L496GDISCOVERY, NUCLEO-G071RB, 32F413HDISC...
ranran by Senior II
  • 568 Views
  • 1 kudos
Resolved! X-CUBE-SBSFU bootloader porting
Hello.I downloaded and tried your "Secure boot & secure firmware update software expansion for STM32Cube" solution.https://www.st.com/en/embedded-software/x-cube-sbsfu.htmlIt works great on my Nucleo-64 board, and the next step what I wanted to do is...
CRC16 CCITT/AUG bad CRC generation
Hi guys,I am testing the CRC hardware of the STM32F722ZE in the NUCLEO board, but doesn't get a right result.The CRC keys are: Poly=0x1021 and INIT value=0x1D0FMy two data input of 16-bit wide is: [0]=0x0031 [1]=0x0032.Some CRC calculators gives 0xEA...
RCata by Associate III
  • 1256 Views
  • 5 replies
Enabling RDP on ST32F746VG crashes the program
Hi!When switching RDP from level 0 to level 1, the program stops working. Switched using code in the program, as well as using the ST Visual Programmer. The result is the same.Code suchFLASH-> OPTKEYR = FLASH_OPTKEY1; FLASH-> OPTKEYR = FLASH_OPTKEY2;...
Asedo by Associate
  • 358 Views
  • 0 replies
  • 1 kudos
Can't link crypto library with IAR 8.11.1
I am working with STM32F407 in a project with crypto library.With IAR 7 compiler version all is oknow I would like to use a more recent version of the compiler IAR 8.11.1 but the link fail with Warning[Lt009]: Inconsistent wchar_t size          cry...
SPI SD Card with CRC
Posted on June 08, 2013 at 11:56Hi, I am looking to understand exactly what CRC support the STM32F103 provides when interfacing with an SD card using an SPI channel and no DMA. I am using an Olimex STM32-P103 development platform and have successful...
dsjnews by Associate III
  • 2132 Views
  • 6 replies
