2018-03-10 2:01 AM
BothUM1974 & UM2179 have exactly the same title:
So how are we supposed to distinguish the two - without having to open both ?
Note: this post was migrated and contained many threaded conversations, some content may be missing.2018-03-10 7:43 AM
These documents refer to different set of nucle-144 boards.
When you select a 144 pin boards here:
http://www.st.com/en/evaluation-tools/stm32-mcu-nucleo.html?querycriteria=productId=LN1847
you will see the particular version of the nucle0-144 document for particular board:
and
2018-03-10 8:54 AM
I think Andrew's point is that it needs to be more obvious from the outside.
The divergence has started with the availability of Ethernet, and now the L4(+) parts.
2018-03-10 9:06 AM
I simply described how I use these documents.
I started from selecting a board so it was not misleading to me as only one document is shown on the particular board page.
Maybe the ST also assumed that we start from selecting a board.
2018-03-10 9:09 AM
Also there a column Part Numbers which might help someone differentiate boards...
2018-03-10 10:43 AM
Yes - that is exactly the point!
2018-03-10 10:45 AM
That misses the point.
The point is that the title should distinguish the documents.
Two different documents should not have identical titles.
2018-03-10 11:01 AM
I honestly got tired of the en.DM00123456.pdf name eons ago, and rename things using the DM number as a base and then a condensed description of the type of manual, rough parts covered, and revision number. That way I have some hope of pulling it out of my STM32 PDF directory.
I also asked ST to put a complete list of older revisions on the same page so I didn't have to dig for them.
2018-03-10 1:16 PM
Not sure how you concluded that I missed the point....
What I want to say: same names do not matter as the the right document is available from the particular product page.
The typical use case is as follows: find a nucleo-144 board -> then find right documents describing the product. And this works because the document (the right one) is available from a product page.
For those who want to see both document on the same page, there is a column with PN (applicable MCU list) on the page where two documents are available so they can be easy differentiated.
2018-03-11 5:27 AM
Bogdan, there are other ways to find these documents. And with these other ways, e.g. some search like for 'nucleo manual' same name for different documents matters.
