STM32 MCUs Products
Programming STM with SWV without nRST pin
Hello,I am programming STM32G491, while I need to use nRST as GPIO (MCO). I am using a code that you can see below. The problem is that when I am debugging a program, the debugger is disconected after HAL_FLASH_OB_Launch(); (this should reset MCU, am...
Resolved! Using SWD pins as GPIO
Hi,at the moment on the STM32U5G9 we have the SWD pins (SWDIO and SWCLK) set to DEBUG, but we would like to also use them as GPIO after programming. How do we switch them to GPIO at runtime? Thank you
Ricko by Senior III
  • 452 Views
  • 4 replies
  • 5 kudos
Resolved! Unable to program my GPIO image on STM32H750B-DK
Hi ,I am not sure but my development board STM32H750B-DK may have some issues and I need some help to find what it may be .  As per the readme.txt (there is very less literature that I could find on this board) , I could dump the ext_mem boot bin int...
nsingh by Associate II
  • 536 Views
  • 7 replies
I can't get spi communication.
Hello.I tried to use an imu that was previously working using the spi2 port of the stm32f4 series with the spi4 port of the stm32h7 series, but I cannot communicate with it. (imu is using icm42688p.)Is it possible that I have made a mistake in my set...
スクリーンショット 2024-11-11 190140.png スクリーンショット 2024-11-19 201830.png baby_chicken_0-1732015139757.png
Resolved! HAL_ADC_Start_DMA caused main loop to become blocked?
Hi, I am configuring the ADC in single-channel continuous conversion mode using DMA. However, once I call HAL_ADC_Start_DMA(&hadc, &AD_RES, 1), the main loop stops executing, and the HAL_ADC_ConvCpltCallback() function is not triggered.I noticed that...
chai2145 by Associate III
  • 624 Views
  • 3 replies
  • 2 kudos
RTCv2 coarse calibration remarks
While the Coarse calibration in RTCv2 is obsolete, in 'L1 and 'F2 it's the only method (and I know 'L1 is NRND, but it's still around and will be for years to come, if ST sticks to its commitment), and as long as it's mentioned in 'F4 it should be pr...
STM32 ADC and DMA with LL libraries
Hello everyone, I'm trying to sample some signals inside a timer ISR. I use all three ADC units of the mC (multiple channels in the first unit and 1 channel in each of the other two units) and I use software triggering and DMA transfer.This operation...
