STM32 MCUs Products
removing chip cause unexplainable artifact.
I have a st chip (HT35) with the STM32H735G-DK Discovery Kit. Projects was complete and running fine. We then had to remove the OCTO SPI nor flash chip because we need access to Pe2. but after removing the chip the app froze after MX_TIM4_Init(). The...
ulao by Associate III
  • 958 Views
  • 9 replies
Multi-channel ADC reading in continuous mode.
Using an STM32H757-EVAL (don't use CM4) with CubeMX. Configured my ADC1 as follows:DMA is:Start the process as follows (both calls return HAL_OK):I allow the code to run for 10 seconds and break. The m_hv_status_values buffer still has the initial va...
_legacyfs_online_stmicro_images_0693W00000bjjM0QAI.png _legacyfs_online_stmicro_images_0693W00000bjjMAQAY.png _legacyfs_online_stmicro_images_0693W00000bjjMFQAY.png
Gil1 by Associate II
  • 1657 Views
skip flash erase before programming
hello,Which command is valid to do this? I see --skipErase, I have also seen --ske, or ske as possible commands to use. What is the syntax for this command? I dont see a reference in the manual...Please help thanks in advance.
RobNeWin by Associate II
  • 710 Views
STM32L4 - SMBus and Melexis MLX90614
Posted on May 23, 2018 at 17:49Hello,I'm trying to read temperature values from a Melexis MLX90614 sensor with SMBus but something seems to be wrong.I used the HAL_SMBUS_IsDeviceReady to see if I can connect to the sensor and I can.#define MLX90614_...
Resolved! SDMMC DATA_TIMEOUT occurs when bus is idle
I'm using an STM32F779 on a known working custom board connected to an EMMC chip (8 wide). I'm using the SDMMC2 peripheral with a DMA channel for Rx as well as Tx and the SDMMC interrupt enabled. My application has two modes, in the first I log data ...
nattayb by Associate II
  • 682 Views
  • 1 replies
