STM32 MCUs Products
Resolved! SRAM internal frame Buffer - LTDC - Strange Issue
hi,I have successfully connected LTDC display(480x272) with STM32H723ZGT6 - RGB565 mode .I could able to image file from internal Flash Memory .I could able to Load Perfect colour from DMA2D by using. framebuffer in global level .uint16_t framebuffer...
MMARI.1 by Senior
  • 376 Views
  • 3 replies
Resolved! EEPROM Help needed
Hi All,Please I need some explenations regarding EEPROM (with SPI interface) .The SPI is working I can see the signals on my LA ,However I have some very basic questions regarding the EEPROM 256Kx8 page size according to the datasheet is 64 bytes per...
Pje by Associate III
  • 834 Views
  • 10 replies
  • 2 kudos
Multilevel Inverter
How generate multicarrier PWM on stm32? Currently my project is making Modified seven level packed u cell inverter.  
Tren by Associate
  • 216 Views
  • 1 replies
Send data over SPI instead of serial wire debug
I am developing some trackers for personal use in VR and have found an excellent solution that meets my needs using the STM32CubeIDE environment and some boards. I create and test the files, but I realize that debugging over serial communication is n...
Syntech by Associate II
  • 1014 Views
  • 7 replies
  • 3 kudos
Resolved! STM32L496 Resetting CAN TEC/REC Counters
I have a system in which the power source to the CAN transceiver interfaced to the on-chip CAN peripheral is common between multiple MCU's vis-a-vis a connector. I have experienced issues wherein if the connection is broken and then re-connected betw...
Library for MQTT using STM32F411RE and GSM module
I am beginner in using STM32 boards I am working with stm32f411re board with that I will use sim900a gsm module for internet connectivity and then mqtt protocol to send data to AWS cloud. So, when I am using paho mqtt library paho.mqtt.embedded-c/MQT...
Reva1605 by Associate
  • 282 Views
  • 0 replies
send AT commands via stm32l011
hello everyone, I have a problem, I have a custom PCB with an STM32L011, I have a sim800l module connected, I send the AT commands via LPUART1 and I want the response on UART2, but as an answer I got AAAAAAAAAAA and after a while Call Ready,Call Read...
Leads for how/where to sell a few spare STM32H7s
If this is not the forum for this kind of question, please let know where to post.I have a few STM32H7 MCUs which I bought once when they suddenly, momentarily became available during the ... Great Chip Shortage.78 units of 100-pin STM32H7VIT6 13 uni...
APagl by Associate III
  • 683 Views
  • 7 replies
  • 6 kudos
