STM32 MCUs Products
Resolved! STM32H747BIT6 Not running code
I have been working recently on a board that i have made for a flight computer. But unfortunately, I have encountered some problems while programing the board.The conection to the board works great, and I´m able to upload de code and read it. The Iss...
Resolved! USBX MSC + FileX + NAND Flash - Windows I/O
Hello,I am building and application with a STM32U575 and a 4Gb NAND Flash. What I am trying to achieve now is to upload files from my PC through USB and then used these file within the STM32 using FileX.I already managed to set up FileX and LevelX to...
Pepils by Associate II
  • 9747 Views
  • 10 replies
  • 4 kudos
Resolved! STM32H7S7L8 dual USB
Hi ,I'm working on the STM32H7S7L8-DK and i would like to know if it is possible to use both USB_FS and USB_HS as two separate Virtual-port-com Device mode When I try to do it for one it is impossible in cube MX to do it for the other.Thanks !
Hamady by Associate III
  • 495 Views
  • 8 replies
Resolved! stm32h723zg Clause 45 MDIO
Hi all,i see H7 supports clause 45 MDIO access, but in the HAL library looks not implemented, i see only clause 22.How should i proceed to read/write c45 ? Thanks,angelo
heisenbug by Associate III
  • 2387 Views
  • 13 replies
  • 5 kudos
