STM32 MCUs Products
ART-PI dev board STM32H750 FMC+LTDC+RGB888 display
Hi all!I wrote code on my ART-PI development panel that displays a simple filled box and text (touchgfx). I use the following in both projects:FMC with 240Mhz, SDRAM with 120Mhz. W9825G6 data 16bitCPU clock 480MhzRGB888 display, MRG7122 DCLK typical ...
H723ZG ethernet fail
Hello,I have made a simple project using NUCLEO-H723ZG to constantly transmit data via UDP with some low but non-trivial speed (~2300 1KB datagrams /s). Unfortunately, after about 3h of such transmission, the board crashed, and afterwards, the ethern...
mbq by Associate II
  • 1264 Views
  • 5 replies
stm32F769I IAP
Hi,I am trying to implement IAP through UART on stm32f779I Evaluation kit,  I am using stm cude IDE 1.9.0 and F7v1.17.0 software package.I have downloaded IAP_Main project using st_link. By using tampered button entered into the downlaod mode and usi...
Aravind1 by Associate II
  • 539 Views
  • 1 replies
STM32 and FLASH registers
I have a question regarding STM32L0. I am interested in which address the registers like FLASH_ACR, FLASH_PECR, etc., are located. In the datasheet, I only see their offsets, but not the absolute value is it maybe 0x1FF8 0000?.Also I would also like ...
JR2963 by Senior II
  • 3692 Views
  • 3 replies
  • 1 kudos
UART communication
Hello everyone, I am trying to make a UART Communication between STM32 NUCLEO-L476RG and ESP32 S3. The STM must send data to ESP and the ESP must print it on Serial Monitor of Arduino IDE. However, this doesn't happen, even though I have double check...
Problem with OpenAmp_ping pong
Dear Support team, I am using this STM32H755 as a motor control application. I have developed motor control algorithm on M4 and the communication with Master through SPI using M7.I need to exchange data between M4 and M7 continuously. I tried with Op...
STM32H7 Prevent MPU re-configuration
Hello all,I wish to setup the MPU early in my firmware, then prevent changes to the MPU registers until next power-cycle/reboot.Is this possible without having the root secure services? The MCU im using is the STM32H7A3. Thanks in advance.
mwp by Senior
  • 2173 Views
  • 8 replies
  • 1 kudos
