STM32 MCUs Products
simple LWIP UDP project not working with latest Cubmx 9.6.2
Hi,I'm using STM32H743ZI with STM32CubeMX 6.9.2 and STM32CubeIDE 1.13.1.I added new STM32 project using the CubeIDE GUI - selected the STM32H743ZI device and automatically the project was generated, I opend the IOC file and enabled the ETH + LWIP opt...
Mz.1 by Associate III
  • 2774 Views
  • 10 replies
DMA is not working on STM32H747i-DISCO board
I am working with STM32H747i-DISCO  board and I configured ADC1 with DMA1 stream0 and ADC3 with DMA2 stream0 both with Cortex-M7 core as initializer and I created the MDK-ARM project using STM32Cubemx and compile the code in CrossWorks when I debug t...
Resolved! Revision code
Hi To what does the revision code correspond?I have not found any clear answer in the documentation.Does a new revision replace the previous one? if so how to know which one is the most recent.
Saredo by Associate III
  • 650 Views
  • 1 replies
  • 1 kudos
STM32 HRTIM BURST DMA CONFIGURATION
Hi all,I am trying to configure burst dma on my board (stm32g474). I have successfully configure the dma for single register, however, when I want to configure dma for more than one register, I failed to do that as it only allow me to fill one addres...
OFN by Associate II
  • 1074 Views
STM32G0B1 Options Bytes
Dear, I currently use a STM32G0B1 on a custom board ans all worked fine until now. My firmware change the options bytes at running to disable the dual bank and using and single bank Flash.At the power up, the firmware check the options bytes and chan...
YDann.7 by Associate III
  • 4312 Views
  • 8 replies
Resolved! Problem with I2C Interface on STM32F469I-DISCO
Hello, I am trying to write something on the I2C bus to a digital potineometer using the STM32F469I-DISCO board but I get no result, even no response from the device and its like there is no device connected on the bus. I tried the same potineometer ...
mids400 by Associate III
  • 1438 Views
  • 3 replies
  • 1 kudos
Resolved! How to switch a pin between open drain and ground
Hi, I have a pin labeled "DISABLE_HV" that I want switch between open drain and ground (and vice versa) to switch-off and switch-on a DC-DC converter. How can I implement this functionality in the code using HAL library?
ECiot.1 by Associate II
  • 2926 Views
  • 4 replies
  • 1 kudos
