STM32 MCUs Products
Resolved! STM32L4 Vbat ADC measurement incorrect
I'm using Vbat as a battery voltage monitor on an STM32L431.  Vref is the VDDA pin on this part, which is 3.3V.  In my test case, Vbat is also connected to the same 3.3V.Vbat reads a raw count of around 1044.  The internal divider is /3, so this come...
JBill.10 by Associate III
  • 1408 Views
  • 1 replies
  • 1 kudos
error: unknown type name 'SPI_HandleTypeDef'
Hi i encounter this error while compiling SPI1 at ST7735.h, i dont understand as this error 'SPI_HandleTypeDef' type was generated by .ioc in main.c already and i had call this statement in ST7735.h. Could anyone kindly help? error: unknown type name...
Resolved! Can't configure DCMI peripherals
HelloI am starting a project with a STM32U585CIU6 and an OV7670 camera module. I want to use the DCMI interface to get the data, and I'm using the Introduction to DCMI to STM32 MCUs document as a reference.STM32U585 datasheet mentions the support to ...
STM32G474xx hrtim1
Hi, I have an inverter project designed with stm32g474xx and there is a "h-bridge" topology in the system.Can I create a uni-polar PWM to get three-level output while controlling this topology with hrtim1? Can hrtim1 generate two complementary PWM ou...
Kayhan by Associate
  • 856 Views
  • 1 replies
DAC trigger by HRTIM
Hi, I need to trigger DAC1 and DAC2 from HRTIM Timer A on a STM32G474. I have set the DAC Sync option inside the HRTIM Timer A settting to generate a DACTrigOut1 event that triggers my DAC1. But DAC has a separate Trigger event that also works for DA...
berait by Associate III
  • 1225 Views
  • 1 replies
Bootloader on STM32H503RB via USB
We wish to bootload a STM32H503RB using USB. This works on the NUCLEO-H503RB, but after resetting the processor on our PCB with BOOT0 high windows reports "Device Descriptor Request failed".AN2606 states that CRS is enabled for the DFU to allow USB t...
CWedg.1 by Associate III
  • 2976 Views
  • 8 replies
Unable to configure Ethernet as RMII
Hello Team, We are prepared our own board for Ethernet Configuration in STM32H745ZIT6 Board then configured peripherals what we need to use in ethernet after configuring ioc file while debug mode every time it will go error handler when it initialize...
ggowd.1 by Associate III
  • 3340 Views
  • 4 replies
