STM32 MCUs Products
I2C Digital Filter use case
Hello Community, I am planning to use I2C operating at 1kHz maximum on STM32G4 & STM32G0 series for measuring temperature from Digital Temperature sensors placed at 2m distance from the main board in an industrial environment using CAT6 (STP) Cables ...
Chubs by Senior
  • 1778 Views
  • 1 replies
Missing section IRTIM in STM32U0 RM and more.
1. According to datasheet, STM32U0 family have an IRTIM (Infrared interface). But this section is missing in RM0503. Also in SYSCFG_CFGR1 there is missing IR_MOD and IR_POL bits.2. In RTC section Figure 297 it is missing RTC_OUT2 and RTC_REFIN pins. ...
AA1 by Senior III
  • 2079 Views
  • 17 replies
  • 3 kudos
Internal Timer of STM32F767
Hello All, I am using the Internal RTC of STM32F767 MCU. The VBAT pin is connected to an External 3.3V Coin Cell Battery At Power ON (Debug window on STM32 Cube IDE), before HAL_INIT when i see the value of RTC BKP1R Register it is 0x5432 as I intend...
STM32G431 SPI Strange Data
Hi Everbody,im trying to setup a SPI com with a DRV8301. im using de STM32G431CBU6. a have read the datasheets mutiple times not saying that i did everything correct but i dont see it anymore. i was hoping that its just a *** mistake and some can pin...
Resolved! STM32H533 Cannot identify the device
Hello,I've designed my own PCB using the STM32H533CET6 microcontroller. However, when I try to connect to it using an ST-Link V2 via SWD, STM32Cube Programmer gives me the error: "Cannot identify the device".I've already tried connecting under reset ...
Szerev_0-1731504786591.png Szerev_2-1731504897424.png Szerev_1-1731504857455.png
Szerev by Associate
  • 351 Views
  • 3 replies
  • 1 kudos
Resolved! STM32H750B-DK Debug issue with SCB_EnableDCache
Hi all. I am aware that this topic has been discussed before here:  https://community.st.com/t5/stm32-mcus-products/debugger-hangs-at-scb-enabledcache/td-p/640648 and here: https://community.st.com/t5/stm32-mcus/dma-is-not-working-on-stm32h7-devices/...
Connect SN65DSI83 LCD to STM32F469
Hi, i'm developing a board with 7" lcd (LVDS) so i'm really hesitating about if is right to use a SN65DSI83 for this, my STM32F469IIT6 only have 2 DSI Lanes. I'm connecting the i2c lane from SN65DSI83 to i2c of STM, i just copied the circuit of cm4-b...
Dual ADC mode single DMA configuration - How?
The STM32H7(4/5) documentation states that two of the ADCs on board can be used in dual ADC mode, so that their 16bit samples are read into the upper- and lower halfwords of a single 32bit register (ADCx_CDR), from where a single DMA can read them in...
MHilt.1 by Associate
  • 1480 Views
  • 5 replies
