STM32 MCUs Products
Resolved! LTDC with Raw RGB LCD
Hello stm community. I am working on a project involving STM32H7 series MCU with Raw LCD panel of 24 bits. Since the display has no IC i am using the internal LTDC component to drive the lcd. So i have some questions can i drive the lcd backlight wit...
b1aze by Associate III
  • 320 Views
  • 1 replies
Resolved! STM32N6 HPDMA not copying data
Hello,another day, another N6 "issue" :)I want to do RAM to RAM copy by HPDMA, but the data never get copied from Src to Dest, Dest always stays unmodified. I have checked the 'DMA_RAMToRAM' example for N6 and went from there, but with no success.DMA...
Low Power I2S MCU
I'm looking for an ST microcontroller that can do I2S receiving while remaining low power, presumably by keeping the core asleep and using DMA to copy I2S chunks to a buffer. I think I saw a video demo of this at some point somewhere on the website, ...
bb00 by Associate
  • 532 Views
  • 5 replies
  • 1 kudos
STM32H753 SPI Slave Tx DMA Problem (Circular Mode)
When using SPI6 in Slave mode with TX DMA in Circular mode, the SPI FIFO is not updated with data from the DMA buffer for the first SPI FIFO size (8 bytes).     Both the SPI Master and SPI Slave were debugged: The SPI Master transmits one frame. On ...
Resolved! STM32F410 uart1 lost break/framing error interrupt
Hi all,Im using STM32F410 uart 1 to transmit and receive.I use DMA to transmit bytes. I then use TC interrupt to send a break,then push an event to an event queue to signal that the transmitter is free.void interface_uart_tx_eot_isr(if_uart_t* p) { ...
law__ by Associate II
  • 694 Views
  • 5 replies
USB VDD issue
We are using the STM32H7R7L8H6H microcontroller in our product design.During firmware initialization, we observed inconsistent behavior related to the USB voltage detector on different boards that share the same hardware design and firmware.Specifica...
Kaushik1 by Associate III
  • 369 Views
  • 5 replies
  • 1 kudos
Resolved! USBPD using CubeMX on H573DK
Hi,I am trying to get USBPD running. I need a simple example code without RTOS. So I used CubeMX. As far as I see it should be easy. All I need to do is:- Turn on the UCPD1 under Connectivity. Here I set "Source". - Turn on the UCPD1 Interrupt- Turn ...
RomThi by Associate III
  • 381 Views
  • 4 replies
  • 1 kudos
Resolved! question aboue bootloader Write_Memory command
Hi, I am tring to write data by the FDCAN bootloader of system memory, my target is STM32H563. Now, I can read the device ID, perform the mass erase command, but I can't write data to SRAM/Flash, the FDCAN bootloader doesn't response any CAN message...
Snaku by Associate III
  • 328 Views
  • 2 kudos
