STM32 MCUs Products
Resolved! Unrecognized device markings
I can't decipher the silkscreen markings on this chip. Could you please help me confirm?This chip looks like it's from ST, but I didn't see the ST logo. I suspect it's an abbreviation for STM32G473ME, but I can't confirm it, and the chip's datasheet ...
topgunZh by Associate
  • 326 Views
STM32U5G9 TrustZone MPCBB
I'm working with the STM32U5G9, trying to configure access to internal RAM blocks with TrustZone enabled.  Part of this configuration uses the HAL_GTZC_MPCBB_ConfigMem() function from stm32u5xx_hal_gtzc.c from STM32CubeU5 v1.7.0.I see in that functio...
rdl_42 by Associate III
  • 408 Views
  • 3 replies
  • 1 kudos
Resolved! NUCLEO STM32U575ZI-Q USB Device CDC Problem
Hello, I am trying to use the STMicroelectronics classic USB device middleware to implement a CDC class in the STM32U575 microcontroller. I am currently working on NUCLEO-u575ZI-Q. At first, I followed the tutorial on "How to use STMicroelectronics c...
IlariaCrupi_0-1709029783341.png IlariaCrupi_1-1709029800660.png IlariaCrupi_2-1709029817595.png IlariaCrupi_4-1709029965795.png
STM32 G071 full erasing problem
I am uploading a custom bootloader to an STM32G071. When I select Full Erase, I get the error "Error occurred during mass erase." How can I solve this? I am using Utility.  
Afsal by Associate
  • 184 Views
  • 1 replies
  • 2 kudos
Blanco stm32h757 programming first time.
Hey,I have an STM32H757 that I’m trying to program for the first time.When I try to program it using STM32CubeIDE or CubeProgrammer, I lose the ST-Link connection after programming one of the cores.Changing the programming order doesn’t solve the iss...
MVops by Associate
  • 267 Views
  • 3 replies
  • 1 kudos
custom surveillance drone with STM32N657X0H3Q
Project Name: custom surveillance droneCase Description:Hi STMicroelectronics Support Team,My name is Shuvadeep Mazumder, and I am the Founder & CEO of Model of Engineering (https://modelofengineering.com). I am currently leading the development of a...
LTDC support
Hi i am working with LTDC with STM32F429ZI Discovery -1 board with onboard LCD. I really want to drive a external LCD RGB display without An ic controller by utilising the Internal LTDC hardware inside the MCU . Can you please give some support on th...
b1aze by Associate III
  • 620 Views
  • 6 replies
  • 3 kudos
