STM32 MCUs Products
Resolved! STM32H747BGT6 MIPI-DSI VDD12DSI
Hi, I have a question about supplying power to DSI interface on STM32H747BGT6 (208 LGFP package).RM0399 says, "The DSI interface is supplied from a dedicated VDD12DSI supply that can be provided eitherby the integrated DSI regulator or by an external...
el659 by Associate III
  • 391 Views
  • 4 replies
  • 1 kudos
Resolved! STM32H747BGT6 SMPS and USB supply pins
Hi, Im planning on using STM32H747BGT6 in LDO mode only and no USB interfaces will be used. What should I do with SMPS pins (VSSSMPS, VLXSMPS, VDDSMPS, VFBSMPS) and USB supply pins (VDD50_USB and VDD33_USB)? The datasheet nor the application note don...
  • 180 Views
  • 1 replies
  • 2 kudos
STM32 Unable to get Core ID
Hi All,I'm new to using the STM32 and honestly had great grief trying to connect to the chip.I'm using STlink V3 and designed my own PCB.Trying to flash a F/W to the PCB. I ordered the PCB from JLCPCB.I keep getting unable to get core ID as a message...
DMA Request Synchronization?
What does DMA Request synchronization do? In the case of SPI_Rx does it trigger SPI reception when TIM12 updates (overflow) if i set synchronization signal to be TIM12 TRGO
LTDC + DSI Video Mode - No Display
I am attempting to display to an ILI9881C based panel. After successfully initialising and testing the panel using DSI only, I am working on DSI Video mode to pull data from a frame buffer via LTDC.I have the DSI configured as follows  static void MX...
Iris-DM by Associate III
  • 1945 Views
  • 9 replies
STM32G4: SPI, NSSP and CHPA
I like to use SPI in continous DMA mode together with a SPI-slave that uses the falling-edge of the spi clock (AS5048A: https://ams-osram.com/products/sensor-solutions/position-sensors/ams-as5048a-high-resolution-position-sensor). So, I have to use C...
