STM32 MCUs Products
Resolved! STM32U575 - available pins for SPI / QSPI
 Hi @Issamos  Am planning to Quad SPI, which port we can use, i cannot able to find the data sheet below listed pins can use Controller -STM32U575VIT6 (LQFP64, 10 × 10 mm)QSPI_CLK → PB2QSPI_NCS → PB6QSPI_IO0 → PD11QSPI_IO1 → PD12QSPI_IO2 → PE2QSPI_IO...
HA2375- by Associate II
  • 757 Views
  • 8 replies
  • 2 kudos
Resolved! stm32H7 LTDC confusion
Hello, I want to use LTDC on the STM32H743VIT6 microcontroller, but when I enable this peripheral in CUBEMX, it does not activate correctly. For example, the pins for B are from B3-B7, while they should be from B0-B4, and the same goes for R, G. 
HOSI by Associate
  • 222 Views
  • 1 replies
Resolved! Can't flash the board (tried 3 different programmers)
Hello, I bought STM32H743XIH6 board and first tried to program it with FTDI programmer and STM32CubeProgrammer. It looks like the serial interface detects the board correctly as I can see it in the STM32CubeProgrammer but fails at a read attempt of 0...
Mondo by Associate
  • 613 Views
  • 4 replies
  • 1 kudos
Resolved! STM32G0 1.5.0 package version
Hello, I am fighting about a week to enable USB-PD comms on my STM32G0B1 MCU and even chat GPT literally told me - he don't have a solution ( shock, a?) One last try before I quit, is to try 1.5.0 package version but I can see in cube MX  only 1.6.0 ...
grisom13 by Associate III
  • 482 Views
  • 6 replies
  • 3 kudos
Missing STM32U5 kernel clock limits
For H7, the kernel clock limit are given in Table 61 Kernel clock distribution overview as shown inhttps://community.st.com/t5/stm32cubemx-mcus/stm32h745-fdcan-clock-frequency/td-p/83540I do not find a similar table for U5 in the most recent datashee...
Resolved! STM32H753 Flash Memory Type
The STM32H753 Reference Manual (RM0433) covers the integrated flash memory inside the microcontroller. It does not say why type of flash is integrated though (NOR or NAND). Is it possible to share what type of flash it is?
Resolved! STM32G474 UART4 RX pin pull up
In STM32G474 UART4 pin no PC11(Rx) is 5 Volt tolerant . If I pull up this pin to +5V with 4.7kOhms then it will affect life or operation of microcontroller? please Suggest.
TIM14 OC1 Trigger into TIM2 on STM32G071
Hi,  Has anyone managed to Trigger Timer 2(Combined PWM Mode, One-Pulse) with Internal Trigger 3(ITR3). The TIM14 OC1 waveform is the trigger. When I run Timer 14 in output compare mode, with an active level on match between Couner and CCR1. I cannot...
