STM32 MCUs Products
STM32H7S7 AXISRAM_WS and XSPICAP options
Hi, I am integrating the STM32H7S7L8H6H in a custom board.  In the reference manual I found two settings which I am looking for clarification for: 1) SBS_PMCR has a AXISRAM_WS bit to enable a single wait state for the AXISRAM.  I do not have ECC enab...
jncronin by Associate
  • 272 Views
GPDMA with linked list for big buffers
Hello !I'm using STM32U5A5 on my custom board.i would like to configure a very big buffer to store lots of ADC samples (60sec circular audio buffer)i check the GPDMA is limited to 64kBI tryed a small test using the linked list to do a small test usin...
Rickou73 by Associate II
  • 255 Views
  • 1 replies
Resolved! STM32H7S7L8H6H XSPI instability
IssueHigher ambient temperatures cause communication malfunctions with XSPI memories.DetailsOur design is heavily adopted from STM32H7S78-DK which also has the same issue described below.The application uses memory-mapped mode for both Flash and RAM ...
SM BUS COMMUNICATION WITH STM32F103RBT6
Hello Experts,Here am using one slave which has SMBUS interface for data transmitting.I am using STM32F103RBT6 for SM BUS and generating the code with STM CUBE MX ,but am unable generate the working code with it and its generating error code.I upda...
HRedd.1 by Associate II
  • 2462 Views
  • 12 replies
  • 1 kudos
Problem setting up UART on STM32F756VGH6
Hi,I am learning and exploring the STM32F756VGH6. My goal is to setup a simple UART and send some data to the PC using USB-UART serial converter and  puTTy terminal on PC. I am using register based coding approach as it makes the code more efficient....
Vilius by Associate III
  • 446 Views
  • 8 replies
  • 2 kudos
