STM32 MCUs Products
14bit DCMI to 32MB SDRAM at 48MHz, on STM32H743IIT6
Hello dear ST forum.I need again you precious help.I am working on a data acquisition device, and need to get 14bit data from a parallel ADC connected on DCMI pins,at 48MHz, and move it to a 32MB SDRAM (W9825G6KH-6I) till almost full. The MCU is STM3...
nedelcu by Associate II
  • 668 Views
  • 8 replies
Using QSPI PSRAM with a STM32-H753 is that possible?
Hello,I am in the process of designing a product which is based on the STM32-H753 and requires P/SRAM.However, I'm concerned the H753 might not support on PSRAM with QSPI, I need the PSRAM for write/read.I haven't found any application notes or examp...
dvir1092 by Associate II
  • 470 Views
  • 5 replies
STM32H7 UART DMA idle interrupt
hello when i use UART Idle interupt with DMA on STM32H743XIH6 chip,i found ,the interupt function will run imediatly when  HAL_UARTEx_ReceiveToIdle_DMA(&huart2, (uint8_t *)Uart2RxBuffer, 50)run,and this is my core code MPU_Config(); // SCB_EnableICa...
QingFeng by Associate II
  • 408 Views
  • 4 replies
Resolved! Issues writing 0s into flash into STM32F103
Hello, I am trying to make a write into flash driver but I am having some issues.I know that the only way to write a 1 to the memory is by clearing the whole page, but I am having issues writing 0s.By reading the manual I encountered: Bit 2 PGERR: Pr...
Resolved! How does the single bank mode operate exactly?
If have read the RM0456 and could not found a detailed description.If I switch the option byte DUALBANK to 0 single-bank mode, what will happen if I access a address which is normally supposed to be in bank 2? Do I get a memory access error?So is my ...
PScal by Associate III
  • 1924 Views
  • 3 replies
  • 1 kudos
Resolved! About the DS11532
Hello ST Community team,On the DS11532: The title of the Figure 20 should be changed to avoid any confusion between figure 20 and figure 21.Also, the note under figure1 is not really clear since the STM32F767 TFBGA216 for example is not compatible pi...
Issamos by Lead II
  • 354 Views
  • 3 replies
