STM32 MCUs Products
HSE clock setup issue on STM32H753-EVAL board
I'm trying to port a proprietary code that is designed for another STM32H753 plateform, to a STM32H753-EVAL board.My code remains stuck waiting for HSERDY bit.The setup I am doing looks identical to STM32CubeHW example but I guess I forgot something:...
Gpeti by Senior II
  • 270 Views
  • 1 replies
How to drive the VD55G0 in N657B0
I want to use N657B0 to drive VD55G0, and the camera side can already enter the Stream state. After I use the function HAL_DCMIPP_CSI_PIPE_Start, I track the variable csi_instance through single-step debugging and find that several bits in its SR1 re...
eureka by Associate II
  • 519 Views
Resolved! Any limits on flash selection for STM32N6
From my understanding all STM32N6 chips need a external flash chip and there's a static stage 0 boot loader.  So if this is true is there any limitation's on the brands of flash or speed/address bit size limitations? With the previous stage 0 bootloa...
Using external RAM with STM32U5G9-HSPI
Hi Everyone,I am working on a project with TouchGFX. I'm working with STM32U5G9ZJT6 and I have an external RAM APS12808L-OBM-BA connected via HSPI (Fclk-hspi 100 MHz) in mapped mode. The project is working, but the image animation are not working wel...
Carlos_Aperton_0-1763041028096.png Carlos_Aperton_1-1763041362659.png Carlos_Aperton_2-1763041490365.png Carlos_Aperton_3-1763041569967.png
Resolved! RM0456 discrepancy in ADC oversampling right shift
In the RM0456 at 33.4.31 Oversampler it say:The division coefficient M consists of a right bit shift up to 10 bits, and is defined using the OVSS[3:0] bits in the ADC_CFGR2 register.But at 33.6.5 ADC configuration register 2 (ADC_CFGR2), it allow up ...
nicolas by Senior II
  • 343 Views
  • 3 replies
  • 1 kudos
Resolved! STM32H7S7L8H6H XSPI instability
IssueHigher ambient temperatures cause communication malfunctions with XSPI memories.DetailsOur design is heavily adopted from STM32H7S78-DK which also has the same issue described below.The application uses memory-mapped mode for both Flash and RAM ...
ADC "shorting" analog input to GND
We're using the following circuit to measure a battery voltage @ 20 kHz for use in motor control.We are having some issues though, where the ADC suddenly starts measuring 0 V (0 in the data register) and gets locked in this state. In this state, we a...
Resolved! STM32U5 FATFS with FreeRTOS
Hi,I'm attempting to write to an SD Card using a Riverdi STM32U5A9 display board.  Since TouchGFX natively uses FreeRTOS, I'm attempting to keep it within FreeRTOS.  Porting to ThreadX has caused it's own issues which I have in a separate thread.  In...
co2meter_0-1763562827680.png co2meter_1-1763562850347.png co2meter_2-1763563015363.png co2meter_3-1763563045901.png
co2meter by Associate II
  • 529 Views
