STM32 MCUs Products
Touchscreen HMI solution
Hello,Does ST mirco provide a readmade Touchscreen HMI solution which can be interfaced with an existing system and display inputs received through the exisiting system on the display with minimum modifications, should be easily configurable and adap...
ATank.1 by Associate III
  • 281 Views
  • 0 replies
Resolved! STM32L496 Missing Bits in SVD-File
Hi,I just downloaded "STM32L496.svd" (Version 1.3) from ST homepage and noticed that there are missing bits in register definitions:CCMR1:Bit 16 -  OC1M[3]Bit 24 - OC2M[3]CCMR2:Bit 16 -  OC3M[3]Bit 24 - OC4M[3]
Resolved! Limitation of SPI3 of STM32U5
I spent many hours trying to make the SPI3 works through the use of the HAL but it was doing weird things (not clearing IRQ flag so ISR was continuously called).Then I found that SPI3 is limited to a size of 1023.I also found on this forum other peop...
nicolas by Senior
  • 608 Views
  • 1 replies
Resolved! STEVAL-MKI109V3 unresponsive after firmware update
I have an STEVAL-MKI109V3 and the MKI238AA evaluation boards.I was unable to communicate with the MKI238AA with the UNICO-GUI software so I updated the firmware on the MKI109 with the ProfiMEMSToolV3.60.7 .bin file using the STM32CubeProgrammer follo...
lylefw by Associate
  • 2199 Views
  • 5 replies
  • 2 kudos
Clock cycle shift on GPIO output STM32F103
Dear Community,I am porting an old application made on AVR to STM32, and I am facing a strange timing issue. In a nutshell, the application is reading sector (512 Bytes) from a SDCARD and output the content of the buffer to GPIO with 4us cycle (meani...
vbesson by Senior
  • 11469 Views
  • 40 replies
  • 3 kudos
Resolved! STM32G431 Comparator BUG
Hi,Few days ago i've encountered a strange behavior of the comparator at STM32G4. I investigated the problem under controlled conditions (used Nuclo kit instead application PCB) and the result is startling.Comparator 4 configured to get positive inpu...
STM32 Timer 8 ETR pin behaving as output
Hello Team,I am using an STM32F469NIH6 in my project and the following is my use case: I need the timer 8 to act as a slave to its ETR pin, which is PA0. I have a signal coming out on the PG7 from my daughter board and I have connected PG7 and PA0 vi...
Jansunil by Associate II
  • 963 Views
  • 4 replies
