STM32 MCUs Products
MIPI Camera on STM32N6
Hi everyone,I'm working on a project with an AR0144 image sensor connected to CSI2. (STM32N6)I have a question: if I use PIPE0 without any ISP processing of ROW10 data from the sensor to memory, do I still need to use ISP?Do I need to initialize it? ...
STM32N6 is only flashable after POR
Hi,We have a weired problem with a custom N657 design.When using the Nucleo board, its possible to flash the program on the external flash, as long as BOOT1=1.The programmer resets the board and it flashes the firmware normally every time.On our boar...
STM32L4R5ZIT6P ESD Damage
Hello,  I may have accidently either shorted or applied voltage to my UART TX and RX pins on my MCU which is on a custom PCB and now my PCB is pulling +60 mA of current under load. I am now experiencing difficulty programming the chip and I am gettin...
ym21 by Associate III
  • 347 Views
  • 3 replies
  • 3 kudos
Resolved! STM32G0B1KET6 CAN Bus-error
Now I've been sitting here for 2 long day's and still haven't been able to solve the BUS-error problem. I'm logging with Kvaser USB CAN card so what I want to see right now is some healthy frames coming out from it, but no, only bus-errors, so I thou...
JSVENS3 by Associate II
  • 659 Views
  • 6 replies
Do FSK or PSK using HRTIM on STM32G474RE
Hello everyone, I'm trying to do FSK and PSK modulation using HRTIM in STM32G474RE but I have what I want when I use Oscillo to display. For example,  '1' = 45 kHz and '0' = 55 kHz. I want to transmit the message "1010" where each bit is 10µs long (F...
mala by Associate II
  • 1402 Views
  • 6 replies
Resolved! STM32F303CCT6 vs STM32F303CBT6
I recently purchased some STMF303 boards for implementing a free pre-compiled HEX file.I received the boards with the STM32F303CCT6 chip, but the pre-compiled file was for the STM32F303CBT6 chip. The HEX loads but does not run on any 303CCT6.Are ther...
