STM32 MCUs Products
How can I exit from standby mode using wakeup pin ?
Posted on October 08, 2014 at 17:48 Hi, I'm using an stm32f401 mcu, mounted above Discovery platform, trying to understand how can I correctly use the standby low power mode; for this reason, I use the PA0 wake up to exit from this low power...
DUrbano by Associate III
  • 1553 Views
  • 8 replies
missed API in stm32cube
Posted on March 19, 2014 at 12:41In some peripheral  some API is needed,for example API functions  for  read and write to a GPIO port is needed(write/read to/from all pins at one operation). another example in usart API functions, that for receiver ...
FFT on STM32F4
Posted on October 08, 2014 at 03:24Hi,Iam trying to use DSP lib on STM32F4 chip. I run the example project of FFT on CMSIS lib and it's ok:an float array ==> FFT ==> result   it's ok.But I try on my board:Signal generator => external ADC => FFT on S...
nhandt3 by Associate II
  • 891 Views
  • 3 replies
STM32F2xx SPI slave receive data problem
Posted on September 12, 2014 at 04:32I have a STM32F2xx connected to FTDI UM232H using SPI communication, STM will configured as Slave and FTDI as Master, I will be using NVIDI have configured my SPI as below: 2 line duplex1 Mhz clockMSB8bitPhase ...
ho by Associate II
  • 279 Views
  • 1 replies
SPI TX trouble on F4
Posted on August 14, 2014 at 19:39 I have an SPI setup using DMA transfers that works for a while, and then reaches a point where the data that is passed to the DMA transfer is not what is sent over the SPI lines. Typically, I am able to success...
SPI Tx Buffer
Posted on July 23, 2014 at 00:57is there is any possibility to clear the SPI Tx buffer after having received or having sent a data ?Thanks in advance,
khalid2 by Associate II
  • 326 Views
  • 1 replies
Problem using RS485 on STM32F030R8T6
Posted on October 02, 2014 at 17:27 Hello, I am trying to initiate a RS485 communication with the STM32F0308DISCOVERY kit. My code is based on the ''UART_TwoBoards_ComIT'' example that I found in the STM32Cube repository (\STM32Cube\Repo...
Recommeded for STM32F407 with DCMI
Posted on September 27, 2014 at 06:01I would like work easly and quickly camera with DCMI on STM32F407. Does anyone know sample source code on this system? I hope the program work parfect when I write to STM32 byEWARM. Actually, I already have a STM...
nagano by Associate II
  • 699 Views
  • 7 replies
STM32F4 NAND Problem
Posted on August 12, 2014 at 18:35Hi, I have a problem with my steval-ccm008v1 evaluation board. When I load ST Mass Storage example everything is fine. I connect my board to PC and format it through Windows. Then I see a filesystem on my board and ...
aveal by Associate II
  • 772 Views
  • 5 replies
