STM32 MCUs Products
Resolved! Nucleo dev board default code
I have a Nucleo-F446RE and C031C6. The default code that came on the board uses the blue button to change the LED blink pattern... Is this code available? It would be very helpful to be able to see how it works.Thanks!!
BLynn.1 by Associate
  • 1113 Views
  • 9 replies
  • 3 kudos
Using Ferrite Bead for VDDA pin
I am trying to design a dev board using stm32 mcu but the issue is I cannot select a ferrite bead I know some basics of ferrite bead but what should I consider from my mcu’s side to select a ferrite bead for it can anyone help me about this or is the...
Asraful by Associate III
  • 257 Views
  • 3 replies
Resolved! CAN TX pin always high in NORMAL mode
I'm trying to set up CAN in the Nucleo STM32H723 eval kit, I can see the message written to the CAN RAM, but I dont see any activity on the TX pin using an oscilloscope. The CAN is configured in NORMAL_MODE, I have testes before with EXTERNAL_LOOPBAC...
MudKIP by Associate
  • 355 Views
  • 3 replies
  • 1 kudos
Resolved! About SPI1,2,3 CLK Config
We are developing using STM32H743.We want to set 100MHz for SPI1 CLK and 117kHz for SPI2,3. However, we cannot set it because of "clock tree" and "maximum divisible limit is 256".Is there any way to achieve the above configuration?
false trigger on break pin b12
Hello experts in my solar inverter i am running pwm at 19k with break enable function polarity high ,i have pulled down breakinput pin with 1k and has not used additional circuit of lm393 yet to control break but the break function falsely trigger au...
ahmash by Associate II
  • 165 Views
  • 3 replies
  • 1 kudos
Resolved! STM32L486VGT6 - Port mapping during Bootloader state
Hello everyone,In my project, I am using the STM32L486VGT6 microcontroller to manage several hardware peripherals. Additionally, I plan to utilize the bootloader feature to flash the code via the USBFS interface.As we know, when the MCU enters bootlo...
NirAlon by Associate III
  • 243 Views
  • 4 replies
  • 1 kudos
STM32F407G-DISC1 expanding I2S2 project
Hello,I am newbie and i have project with STM32F407G-DISC1 and PMOD I2S2. It generates two RNG values at start and with buttons switches digital filter correspoding to RNG value and shows it on LED in binary. Digital filter length and coefficients ar...
CzyzyK by Associate II
  • 230 Views
  • 0 replies
STM32H7 PCx_C pins unusable for boundary scan?
Hello,I used CubeMX for a design for H75x in LQFP176.I was able to configure SDCKE0+SDNE0 signals of SDRAM Bank 1 to PC2_C and PC3_C.Now I wanted to configure a SDRAM test using JTAG boundary scan but the JTAG tool manufacturer claims that these PCx_...
regjoe by Associate III
  • 1026 Views
  • 9 replies
