STM32 MCUs Products
PyOCD Programming
Hello, I’m trying to use the PyOCD library to program an STM32H747 and an STM32U5A9 using .hex or .bin files generated by STM32CubeIDE. So far, I haven’t had much success, and I’d like to know if anyone has experience with this or can offer guidance ...
Resolved! Nucleo-303RE Not Starting Up
I am using a Nuclro-303RE to develop a USB Virtual Com port, and I am running into an issue that I cannot seem to resolve.  Just to verify things, I did put some really simple code in the flash the green indicator on the Nucleo board.I have it connec...
Nucleo-F303RE-Clock.png Nucleo-F303RE-USB.png Nucleo-F303RE-VCOM.png Bryon08_0-1744207627697.png
Bryon08 by Associate II
  • 199 Views
  • 5 replies
  • 2 kudos
Using STMCubeIDE and Micropython
I want to add a USB thumb drive (mass storage) to a NUCLEO-144 F767ZI board. I see the STM32CubeIDE can be used to point GPIO lines PA8~PA12, PG6, PG7 to connector CN13 (USB Micro-AB) or to the Morpho connectors to realize a USB OTG (On the Go) inter...
STM32F746ZG DFU MODE
HELLO guys could you please tell me how to put the stm32f746zg board in dfu mode actually earlier i was able to program and use the stlink to dump but currenty im not able to connect using stlink so i want to do with the dfu stm32 bootloader mode i h...
joyson by Associate
  • 193 Views
  • 3 replies
  • 1 kudos
Corrupted data waveform in specific LTDC data lines
I am going to set up a RGB666 LCD with STN32F779 and Frame buffer in SDRAM. The problem I'm facing is that there are a series of parallel dark lines in the image.I first tested the SDRAM and the reading and writing is done correctly. Then I realized ...
Slh_4-1743094968002.png Slh_1-1743094374198.png Slh_2-1743094447545.png Slh_3-1743094558893.png
Slh by Senior
  • 203 Views
  • 3 replies
  • 2 kudos
Resolved! Standby mode on stmL433 drawing too much current
Hi   I have a a stm32L433 48 pin processor and trying to get it into low power. I am using the STLink-V3PWR module with stm32Cube Monitor Power module.   First of all I placed a known value resistor across the STLink-V3PWR to make sure it is reading ...
