STM32 MCUs Products
STM32H533CET6 ADC Reading
I am encountering an issue with ADC readings on a custom board based on the STM32H533CET6.Hardware Setup: I have a simple analog filter connected to the ADC input. I have verified the input signal with a multimeter, and it correctly varies from 0V to...
Karol123 by Associate
  • 274 Views
  • 3 replies
STM32H743 as USB Host stops communicating
Hello, I have a problem that I am having a hard time figuring out.My project is using an STM32H743 as a USB host on a custom PCB. Both OTG_HS and OTG_FS ports are connected to different devices. OTG_HS is using the internal PHY and operating at full-...
Resolved! Ruling out fake STM32G474s
Hi,I'm facing some issues with some STM32G474RET6s, and want to rule out counterfeit chips, even if that seems unlikely.After googling for some solutions, I confirmed the AP IDR register and the DBGMCU_IDCODE both hold a revision ID of 3, which I exp...
abond by Associate
  • 999 Views
  • 8 replies
  • 3 kudos
USB mass storage error on STM32H7 core M4
Dear all, i have a problem with my custom board based on STM32H745.I need to use core M4 with USB_HS host with mass storage class (a pen drive) at 12Mbit full speed (internal Phy transceiver).I have configured the processor as per attached file (core...
Resolved! RTC not working on Vbat
Hi everyone,I am using a STM32H563RG and I need the RTC to work even if the VDD is powered off. To do that, I am plugging a battery on the VBAT pin to power the RTC and the Backup domain. But I tested it and it seems the RTC is stopped and the backup...
Karakala by Associate II
  • 670 Views
  • 10 replies
  • 6 kudos
