STM32 MCUs Products
Resolved! Need details about STM32 I/Os
Posted on May 24, 2017 at 18:24For my design i am already using STM32F429BI--LQFP208 package, Now i am looking to replace this with STM32F777BI-LQFP208, both are pin compatible..Question: In the data sheet of STM32F777BI Its mentioned that GPIO'S=15...
0690X0000060761QAA.png 0690X0000060766QAA.png 0690X000006076FQAQ.png 0690X000006070dQAA.png
STM32F407 + LwIP + FreeRTOS: ethernet fritz
Posted on May 25, 2017 at 08:24If CHECKSUM run by SOFTWARE ethernet fritz in some packets (spam).//#define CHECKSUM_BY_HARDWARE in lwipopts.hEthHandle.Init.ChecksumMode = ETH_CHECKSUM_BY_SOFTWARE; in ethernetif.cHow can i fix it?
pestov by Associate III
  • 285 Views
  • 0 replies
Resolved! STM32F3xx device driver / lib lack
Posted on May 23, 2017 at 18:02I dont know I must be wrong but I didn't find function call to change the dutycycle of a pwm so I wrote this and I added it to stm32F3xx_hal_tim.c/**  * @brief  Set the PWM DutyCycle.  * @param  htim: TIM handle  * @pa...
o gaste by Associate III
  • 482 Views
Resolved! OPAMP output: VDDA overconsumption
Posted on May 22, 2017 at 15:35The STM32L471 Errata document states that:  An overconsumption can appear on VDDA in the following conditions:• a voltage VPAD is applied on PA3 or PB0 with VDDA+ 50 mV < VPAD < VDDA + 600 mV ...Our application uses ...
Chris1 by Senior III
  • 699 Views
  • 6 replies
How to receive a lot of characters from USART???
Posted on May 22, 2017 at 14:13HI I want Receive characters from USART. I don't  know how much characters will be sentand the data that will be sent is too much. in interrupt mode i will receive amount interrupts and it is not good(for example 1000 ...
l90mehdi by Associate II
  • 550 Views
  • 4 replies
relocation truncated to fit: R_ARM_THM_JUMP11
Posted on May 24, 2017 at 14:34Hello, I want to make a branch from startup file like this :Default_Handler:  b exception_panic  .size Default_Handler, .-Default_HandlerBut i'm getting this error : relocation truncated to fit: R_ARM_THM_JUMP11 agains...
Floating and printf not working
Posted on May 22, 2017 at 14:13Hello,I would like to print floating variable with printf but it is not working. i'm using a stm32l073 MCU that does not have any FPU. I'm activating  -u _printf_float  in my llinker but it doest not change anything. A...
