STM32 MCUs Products
Resolved! RM0316 (STM32F303) - COMP2_INP_DAC
In RM0316 rev.10, in Table 109. COMP register map and reset values, bit 1 of COMP2_CSR is marked COMP2_INP_DAC, whereas the STM32F303 are not supposed to have this bit (only STM32F301/302x6/8 do) - probably a copy/paste artefact/relict.Can ST please ...
STM32H7S7L8H6: VBAT connection
Hello Team, Query related to VBAT. Please refer below capture and provide your feedback for VBAT. Diode D1 and other components are, ok? Thanks & Regards,Jignesh Karena
JK1234 by Associate III
  • 352 Views
  • 7 replies
“STM32L433RCT freezing (lock-up) problem
Hello, I am experiencing the following issue with the STM32L433RCT microcontroller I am using: when I pull the NRST pin LOW and then release it to HIGH, the microcontroller does not recover from reset. In this case, power cycling the device does not ...
Resolved! STM32C071 USB Issue (blank / bootloader, and programmed)
We have been playing with the NUCLEO-C071RB for a few weeks, waiting for our first revision of a board using the STM32C071KBT to be fabricated and assembled. We got most things going without issue, including USB CDC + HID. Power up of the custom boar...
scenic_0-1766029228155.jpeg scenic_1-1766029248986.jpeg scenic_2-1766030031951.png scenic_7-1766030983717.png
scenic by Associate
  • 271 Views
  • 1 replies
  • 1 kudos
