STM32 MCUs Products
Resolved! CubeMX : Adding Additional expansions
Posted on April 04, 2018 at 18:17How can I add STs expansion packs. http://www.st.com/en/embedded-software/stm32cube-expansion-packages.html?querycriteria=productId=LN1920 But how can I add them, a timer tool could be useful.There was a thread about...
LMI2 by Lead
  • 404 Views
  • 1 replies
FMC-SDRAM
Posted on April 03, 2018 at 07:49Hello, I will use FMC for SDRAM. I looked examples and tried. But this examples used Bank2, I want to use Bank1. How can I do ?
Timer Interrupt not working on STM32F103C8
Posted on April 04, 2018 at 14:51I am using CubeMX and SW4STM32 to generate timer update interrupt on STM32F103C8. The core is running at 64 MHz, and I have verified that other functions like GPIO, PWM, ADC work perfect.The target is to generate an ...
STM32L452 SystemClock_Config with STM32CubeMX
Posted on April 03, 2018 at 12:27Hi,I have Nuckeo-L452RE with STM32L452RE uC on board.This uC max speed is 80MHz.But after enabling MCO on pin PA8 in STM32CubeMX and generating the code to Atollic, I could see wrong SYSCLK frequencies.The reason of ...
Where are _IRQHandler functions defined?
Posted on March 04, 2017 at 16:13Ok so I am talking about the IRQ handlers for ADC, SPI, I2C USART etc.. I am expecting to see weak definitions of ADC_IRQHandler() function for example somewhere...but my startup_stm32.s file in startup directory doe...
NUCLEO-F767ZI Demo Software
Posted on April 04, 2018 at 16:58Where can I find the source of the demo software which is already loaded on a 'fresh from the box' NUCLEO-F767ZI please. I searched the forum and looked on the ST nucleo web pages already.Thanks - John F.
John F. by Senior
  • 789 Views
  • 3 replies
Resolved! USART3 voltage level
Posted on April 04, 2018 at 22:31I'm using STM32F207ZG ,What is maximum Voltage level at Tx and Rx pin in USART3? Can I use 5V CP2102  USB to TTL converter with STM32F207ZG?
