STM32 MCUs Products
STM32F030C8 warm start failure
We have several STM32f030C8s that refuse to start if the ambient temperature is 40deg C. Below, say 20 deg C, they start and continue to run up to and beyond 40 deg c ok. Applying a reset on a stalled processor brings it to life. Is this a known p...
DPidd by Associate II
  • 1143 Views
  • 5 replies
Resolved! Rotary Encoder Application
I am using STM32F103C8T6 for counting rotary encoder pulse.My Encoder PPR is 5000.But when I program for timer1 as encoder mode and show count on segment it shows 20000 pulse per rotation it is 4 times higher than the actual value. What should I do t...
JPanc.1 by Associate II
  • 1240 Views
  • 3 replies
How to do STEP/DIR interface?
Hello,I need to connect STEP/DIR driver (DRV8825 to STM32F103) for driving one axis stepper motor. I will use buttons for moving and I need to set acceleration and deceleration profile. Do you have some experience what way of pulse generation I shoud...
TIM_OCMODE_ACTIVE output problem ?
I config timer'mode is TIM_OCMODE_ACTIVE  , start enable ,can output waveform,but enable more than one time , only output the first corresponding waveform .why behavier so ?but when I config timer TIM_OCMODE_PWM2( or TIM_OCMODE_PWM1 ),enable and di...
Resolved! TIMx Clock Division Configuration
Hey, I am trying to understand timers, everything goes nice, but I have a question in my mind.I am able to set the prescaler and period values according to my purporse, but I can't use the internal clock division effectively.My TIM2 clock signal is 1...
YAkse by Associate III
  • 6199 Views
  • 8 replies
  • 4 kudos
About Timers triger ADC
How to config Timers when I want to use it to triger ADCs, May I get an example?STM32F103​have already been solved
CWang.4 by Associate
  • 433 Views
  • 0 replies
Resolved! problem with TIM exception stm32f103
So I just started to use stm32f103 MCU that I have but for some reason I code doesn't go into the TIM2_IRQHandler.This is my code:.thumb .syntax unified .equ GPIOB,0x40010C00 .equ RCC ,0x40021000 .equ TIM2 ,0x40000000 .equ NVIC ,...
FEkic by Associate II
  • 2423 Views
  • 8 replies
