STM32 MCUs Products
Resolved! Need help understanding performance issue on STM32H743
I'm struggling to understand why I'm seeing a huge performance hit by slightly changing code in a loop. I narrowed down the problem to a manageable code size, and I'm hoping someone here can suggest how to investigate and resolve my issue.I'm using a...
fbar by Senior
  • 2670 Views
  • 5 replies
Used SPI 4 for two different interfaces
Hi All,I am using STM32F427ZIT6 MCU for one project. I connected SPI4 for two different interfaces by mistake. Pins 1,4,5 for one interface and pins 64,65,66,67 for one interface.I want both the devices working simultaneously. Is there any solution f...
DKS by Associate II
  • 694 Views
  • 1 replies
DBroo.1 by Associate III
  • 783 Views
  • 3 replies
SD Card Time out STM32F779II
I'm using STM32F779II With a microsd card. That is clocked at 48MHz.When writing to the sdcard as a block, I get HAL_TimeOut, using that function: err = HAL_SD_WriteBlocks(&sd_handle, (uint8_t *)src, block_num, num_blocks, 6000);After writing I wait ...
Receiving a burts of data from SPI using DMA
Hi, I am using an STM32f407VGT MCU and I am trying to receive a burst of data of 112 bytes from SPI1 and storing it in an array buffer, initially set with all its elements to 0.According to the RM0090 TRF this should be easily done with the DMA, but ...
simo zz by Senior II
  • 1996 Views
  • 12 replies
Linker Error: "no definition for __write".....
Hey everyone, I am using IAR and a STM32F401RE.When I am setting the library low-level interface implementation to "None", I get the following linker error:Error[Li005]: no definition for "__write" [referenced from fflush.o(dl7M_tlf.a)]Error[Li005]: ...
JCorn.2 by Associate II
  • 3963 Views
Resolved! I have a question about using flash memory.
HI Sir.I will try to work on a project using STM32.I have a question regarding flash memory usage.I want to  save input data to flash memory but STM flash memory is divided sector.The capacity of each sector is determined.ex) STM32F205VE Sector 0 : 1...
User.72 by Associate II
  • 933 Views
