STM32 MCUs Products
Resolved! Having Problems activating SysTick after Stop mode
I'm using STM32F070CBT at 8mhz with almost all pins active (used for GPIOs, PWM, SPI,I2C,etc) , i'm using a timer to enter stop mode with low power regulator and waking up using GPIO external event, after waking up i checked that PWMs and GPIOs are s...
HMucc.1 by Associate II
  • 1110 Views
  • 3 replies
STM32N6 Image Classification Example code to run on Keil
Hi,     I am using STM32N6570-DK kit. I have an example project for image classification, but it is designed for STM32CubeIDE. I want to port this project to Keil ( in order to use the ARM Compiler). Could you please provide the project file so it ca...
VasuV by Associate
  • 141 Views
  • 0 replies
Flashing chip on pcb
I am trying to flash a chip on a PCB. Right now I just have it toggle an LED. Sometimes it connects, but does not toggle, only stays lit. After power cycling, it does not even light up, it just stays off. Is there something i am missing, perhaps in t...
at3 by Associate III
  • 554 Views
  • 18 replies
  • 8 kudos
Resolved! EEPROM SPI Reading issue
Hello, I am trying to write and read from stm32f105 to an eeprom 93AA46A, using Full-Duplex Master. To write into the eeprom, I am using following code:void EEPROM_WriteEnable(void) { uint8_t cmd = EEPROM_CMD_WRITE_ENABLE; //0x98 EEPROM_CS_H...
Siva21 by Associate II
  • 726 Views
  • 17 replies
  • 5 kudos
INTERFACING 32bit RAM With STM32H750XB MCU
Hi,     Please share pointers on interfacing 32Bits RAM along with STM32H750XB MCU with QUAD SPI External Memory and 8 MB Frame Buffer RAM on STM32H750XBRAM - IS42S32400TFT USED  - 1024x600 at 24 bpp and or 1024x800 at 16 bpp at 60 + FPSAre These Set...
Caan by Associate III
  • 351 Views
  • 3 replies
Low cost 16bit ADC
Posted on February 11, 2015 at 13:01Hi, Does anyone familer with Low cost microcontroller with 16bits ADC  (below 1.5$) ? Thanks
udibit by Associate II
  • 1558 Views
  • 6 replies
