STM32 MCUs Products
STM32L Discovery, How to output HSI with MCO
Hello.I am currently developing with STM32L Discovery.In preparation for development, I tried to output using the MCO in order to know the exact frequency of the HSI of the evaluation board used.By operating MCOSEL in the RCC-> CFGR register, MSI and...
ota-s by Associate II
  • 2426 Views
  • 10 replies
DMA memory to peripheral question.
Hello,I have a doubt regarding DMA memory to peripheral ?Suppose I would like to transfer a memory buffer content to SPIx TX.When do each transfer occurs ? Every time I change the content of the memory buffer ? Always ?I cannot find this information...
simo zz by Senior
  • 370 Views
Unnecessary SD card command in block read/writes
Hi,When looking into stm32l4xx_hal_sd.c, I observed the following code:   if(hsd->SdCard.CardType != CARD_SDHC_SDXC)   {     add *= 512U;   }   /* Set Block Size for Card */   errorstate = SDMMC_CmdBlockLength(hsd->Instance, BLOCKSIZE);   if(errorsta...
Lama by Associate III
  • 1044 Views
  • 7 replies
  • 1 kudos
Problems with configuring the FDCAN of the STM32H743ZI
We have the following situation: We want to use the FDCAN of the STM32H743ZI with 500 kbit/s. We've got followingconfiguration parameters for the FDCAN1:hfdcan1.Instance = FDCAN1;    hfdcan1.Init.FrameFormat = FDCAN_FRAME_CLASSIC;    hfdcan1.Init.Mod...
TPien by Associate
  • 390 Views
  • 1 replies
coocox os RTOS with stm32l0
I want to use coocox os with an stm32l083cz . while i am compiling the code the following error appears. /tmp/ccpwcyyg.s: Assembler messages:/tmp/ccpwcyyg.s:242: Error: selected processor does not support `stmdb R0!,{R4-R11}' in Thumb mode/tmp/ccpwc...
Resolved! Measuring exact time between to pulses
Hi all,To be hontest, I am a beginner when it comes to timer and capture hardware. Maybe someone can help me figuring out what the best way is how I can measure the time between two separate impules i get on two separate lines. Accuracy shall be very...
Microman by Associate III
  • 1960 Views
RTC wake up
Implementation on: STM32L476RCI can configure a periodic sleep cycle by waking up through the RTC through calling HAL_RTCEx_SetWakeUpTimer_IT.I'm now trying to handle an EXT interrupt while in this periodic sleep cycle.The goal is to handle the EXT i...
Aa.41 by Associate II
  • 297 Views
  • 0 replies
