STM32 MCUs Products
Resolved! RCC_CR.HSEBYP not reset by Software Reset
Experimenting with STM32F427 and STM32F446 I found out, that the RCC_CR.HSEBYP bit is *not* reset by Software reset. It is reset only by NRST and Power-On reset.While applications where this could lead to problems (i.e. where HSE clock source is chan...
Resolved! STM32H562 - 5V Tolerant Pins Derating Impact
Hello Community,We are currently evaluating the STM32H562IGT6 microcontroller for our development project. During our review of the device’s pinout, we observed that several GPIO pins are designated as FT (5‑V tolerant). We would like to request clar...
RajeshM by Associate II
  • 152 Views
Programming an STM32H7 for Samsung eMMC Support
Hello, I've just received my custom PCB with an STM32H743VIT6 MCU. It has a Samsung eMMC connected to the SDMMC1 interface (MMC 8 Bits Wide Bus) : (I'll link the eMMC datasheet below.) I'm encountering some issues while initializing the device with ...
yaxsomo_0-1737130265822.png yaxsomo_1-1737130504759.png yaxsomo_2-1737130510135.png yaxsomo_3-1737130514249.png
yaxsomo by Associate III
  • 2005 Views
  • 5 replies
  • 1 kudos
Resolved! STM32H562/3: clarify the max frequencies in DS14258 rev6
According to the STM32 datasheet, the maximum clock frequency of TIM6 and TIM17 is shown as 64 MHz, while that of TIM1 to TIM8 is shown as 200 MHz. There is a conflict in the documentation, so please confirm which one is correct. (DS14258 Rev6,page 1...
Adu_It by Associate
  • 379 Views
  • 1 kudos
Resolved! USBX issue in the STM32N657X0H3Q (Nucleo-N657x0-Q) board
  We are working on a bare-metal application using USBX on an STM32N657X0H3Q device.In CubeMX, we configured USB1_OTG_HS under Connectivity and enabled USBX in Middleware. However, when we execute the following function: static void MX_USB1_OTG_HS_P...
Grace_04 by Associate III
  • 394 Views
  • 3 replies
  • 1 kudos
internal temperature tamper not triggering
hii am using stm32u585 controller for my project . here i enabled the internal tamper detection using the below code  /* USER CODE BEGIN TAMP_Init 2 */ sAllTamper_inter.IntTamper = RTC_INT_TAMPER_1|RTC_INT_TAMPER_2|RTC_INT_TAMPER_3|RTC_INT_TAMPER_9;...
sabari1 by Associate III
  • 205 Views
Resolved! STM32H723 - ULPI and pc2_c/pc3_c
Hi all,I'm currently designing a board that requires using an stm32h723 with USB HS (I need more bandwidth than FS allows). The stm32h723 I'm using doesn't expose pc2 or pc3, which are needed for ULPI DIR and NXT respectively. Instead, pc2_c and pc3_...
sophie by Associate II
  • 613 Views
  • 5 replies
