STM32 MCUs Products
Resolved! STM32F417VGT VCAP Voltage Problem
Hi everyone!I am having a hard time making my design work.I prepared a long list of what I did and what I observed to paste into ChatGPT.I am pasting the exact text below:I designed an digital circuit using STM32F417VGT microcontroller.I applied 3.3V...
SalihKun by Associate II
  • 2115 Views
  • 12 replies
  • 5 kudos
emmc interfacing with NUCLEO board
I’m interfacing the STM32H755ZI-Q Nucleo board with an MTFC8GAMALNA-AAT eMMC. What configurations are necessary for this interfacing? I’m also getting warnings in the RCC configurations. Could you guide me on the settings needed for SDMMC1 and FATFS,...
sai1 by Associate II
  • 386 Views
  • 0 replies
Resolved! Questions about SPI6 and BDMA
We are trying to transmit data using SPI6 and BDMA.When we perform the following process, we are able to transmit 1 byte + 1 bit of data, but after that, MISO outputs High no matter what the value of the transmitted data is. What is wrong with this? ...
Resolved! Ext. Interrupt conflict on STM32H7 ?
Hello, I'm using H723 Nucleo. I set 5 ext interrupt pins: PA0, PA1, PA4, PC2_C, and PC13 as EXTI to 5 switches, enabled NVIC interrupt, GPIO pull-up,  interrupt with rising edge triggered, and tied these 5 pins to switches with the other end to groun...
DSIHOST_D1P pin used as GPIO
Hello,I'm wondering if there's a way to use the DSIHOST_D1P and D1N pins as GPIOs, or if it's possible to simulate GPIO functionality on these pins. Currently, I don't see any GPIO configuration options for them in STM32CubeMX. The MCU in use is the ...
