STM32 MCUs Products
SMBUS/ PMBUS Expansion Package
I am trying to implement the PMBUS on STM32 processor using SMBUS/PMBUS exapnsion package. I am able to execute the read and write commands. But when I am trying to execute the READ_OR_WRITE command for read operation then I receive only FF FF in the...
NAgar.1 by Associate
  • 949 Views
  • 1 replies
why current consumption in low power sleep mode(LP SLEEP) on stm32G071RBT6 is around 1mA, not less than 100uA as spec?
I'm working on NUCLEO G071RB board to measure current consumption MCU STM32G071RBT6 in LP SLEEP mode. I run the example https://github.com/STMicroelectronics/STM32CubeG0/tree/be65d071640424445aa265e8b9a058e44b8decb7/Projects/NUCLEO-G071RB/Examples/PW...
DThan.1 by Associate
  • 794 Views
  • 1 replies
How to generate sinewave by using DAC in stm32h745xg ?
we are using stm32h745xg and I initialize DAC with timer 6 ,we enable DMA also.we are using following code  static TIM_HandleTypeDef htim; TIM_MasterConfigTypeDef sMasterConfig; /*##-1- Configure the TIM peripheral ##################################...
srikanth by Associate III
  • 562 Views
  • 0 replies
Hi, I am completely new to STM32 MCU programming. I am trying to make a simple variable frequency complementary square wave generator with my STM32F103C8T6 blue pill to drive an inductive load. I'd like to use a potentiometer to vary the frequency.
Frequency range I'm looking for is from 60 kHz to 200 Khz. Here's the code I generated with Cube IDE. It initializes the GPIOs, ADC, and PWMs but I don't know how to integrate a potentiometer in this code and be able to vary the frequency of the comp...
SGulc.1 by Associate
  • 846 Views
  • 1 replies
TTCAN in STM32F767
Hello I have read on the reference manual that the CAN controller can be set to work as TTCAN by setting the TTCM bit. But comparing with the STM32H7 it seems that only the latter family has the TTCAN functionality.Someone has experience with that ?R...
DVicc.1 by Associate II
  • 853 Views
  • 1 replies
