STM32 MCUs Products
How to use USART RTO timeout?
I have a STM32L4xx series microcontroller. My goal is to use RTO in USART to issue a timeout, from the time a read was attempted (not only from the last stop bit). This is needed as its possible for nothing to be received. How do I acheive this using...
Accessing outside flash area is working...
Tested to flash a 128k (STM32F105) device with a firmware (40k) that is compiled for 256k and it works. Even when the firmware reads and writes data (config) to address location 0x0083E000 which is way out of the 128k device memory area.Is there some...
HHaga.1 by Associate
  • 971 Views
  • 3 replies
Experiences with STM32 and XRay or CT
Hello,during qualification tests, our design with STM32 L4 first went through XRay tests and afterwards even CT to check for soldering problems etc.XRay was fine, but we have an issue with CT were the controller quit function afterwards. Not even a J...
RHaag.1 by Associate II
  • 1356 Views
  • 5 replies
STM32 ADC acquisition after some amplification block
Hi, I have a random amplitude signal with 10 us period, coming from DAC channel 1 of the STM32 connected to some block with amplifier and switches. The block is finally connected to an input channel of the ADC within the STM32. The block ...
VKuma.11 by Associate
  • 662 Views
  • 1 replies
Resolved! STM32G070RB HSI16 Clock and clock calibration issues. Is there a clock calibration example without the need to use HSE or LSE clocks?
I am trying to acquire the amount of ticks a timer counts using a 50Hz signal (acquired from the mains using hardware). For this I use a EXTI8 interrupt where the 50Hz signal is sampled. I can see on the scope that this interrupts works perfectly (by...
CP.Tang by Associate II
  • 1933 Views
  • 5 replies
Software SS management issue of H753's SPI
On Fig 613 of RM0433, the SS connects to Vcc. According to 50.4.7, it is said the SS pin is free for GPIO when in software SS management mode.Does fig 613 mean SPIx_NSS pin can not be used GPIO when corrsponding SPI in software SS management mode?
JZou.2 by Associate II
  • 454 Views
  • 0 replies
